Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: [SOLVED!] 2JZ-GTE Swap into MA70 - Misfiring issues - Will PAY for a correct answer..
    May 2007
    Default Re: [UPDATE!] 2JZ-GTE Swap into MA70 - Misfiring issues - Will PAY for a correct answ
    Quote Originally Posted by richardjeffries View Post
    It's finally fixed.
    .. and to think someone could have made $100 if they asked if I had checked for spark ..
    glad to see you got it sorted... this being said the fact that you changed plugs and coils etc one would have assumed testing spark was one of the 1st things uve done lol...
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
    Sep 2011
    FL
    Quote Originally Posted by midnight_purple_GA70 View Post
    If you read my post above you'd see that I did test spark but at the time I found I had the igniter pinned incorrectly (backwards, read the schematic wrong!) and fixing the problem I assumed I had spark.
    Not to mention, as I said, the spark plugs were all identical.. so I naturally assumed spark was the same on all cyl..
    Live and learn!
    May 2010
    Moscow
    Default Re: [SOLVED!] 2JZ-GTE Swap into MA70 - Misfiring issues - Will PAY for a correct answ
    Congratulations!
    In fact your experience may save even more than 100 bucks. Though still I don't quite believe. When I was swapping 4-speed to 5-speed auto on my 1jz-ge, mate helped me transplanting the loom. 2nd coil connector was broken in new loom,and he just isolated crimped terminals and put them in, didn't say a thing to me. I was busy connecting things inside car at the moment. The mate was unaware of polarity thing and reversed it. I was driving for a year before noticed the lack of connector and polarity reversal, everything was just fine.
    Gotcha. Is there such thing as an OBDII 2JZGTE Auto J-Spec ECU?
    what is J-spec?
    2jzgte with vvti has obd2-style connector but it still needs specialized scanner/software.
    Though physical layer is k-line, like in your 1993 engine. Free scanner software exists as well.
    Sep 2011
    FL
    Interesting story, George. I find it odd that the polarity sometimes matters and not other times. That's very interesting.
    When I said Jspec I meant JDM/MAP based, not USDM/MAF/AFM based.
    I wonder if there was an auto Aristo with OBD2 or auto JDM Supra with OBDII. Hmm.. apparently it's (mostly) a direct swap, just have to add a few things (secondary o2 and whatnot). I'm still automatic obviously.
    May 2010
    Moscow
    I once swapped such an engine off JZS161 Aristo, but it had MAP *and* MAF. And it was tricky to find ECU without immobiliser.
    Sep 2011
    FL
    Hmm very odd. Maybe I should just go standalone.
    Tallahassee, FL USofA
    Quick test for ignition coil polarity.
    http://mgaguru.com/mgtech/ignition/ig104.htm
    http://www.chicagolandmgclub.com/tec...neral/574.html
    I've never seen a difference, maybe on a dyno at WOT or with a marginal coil there is.
  8. #38
    Sep 2011
    FL
    Well I can tell you first hand, that today I had no spark on cyl #4 until I swapped the polarity.. very odd
  9. #39
    May 2010
    Moscow
    btw, allencr - very interesting info! I didn't pay attention too much to the fact that this winter I had very poor start with outside temp below -18 C. I only noted it supposingly became worse after I swapped loom. Now it seems like wrong coil polarity could be among other reasons for that.
  1. 1uzfe ,host of issues in my swap please help
    By taka21 in forum Tech and Conversions
    Last Post: 12-07-2011, 10:21 AM
  2. JZ Misfiring/backfiring issues
    Last Post: 29-06-2011, 02:44 PM
  3. 2JZ-GE engine+gb swap into jzs147 tt aristo adaptability
    By 1jzfanatic in forum Tech and Conversions
    Last Post: 16-06-2011, 11:56 AM
  4. Aristo 2jzgte auto - extension housing swap over
    By wrench in forum Tech and Conversions
    Last Post: 31-05-2010, 06:16 PM
