Results 1 to 5 of 5
Thread: 2JZ-GE engine+gb swap into jzs147 tt aristo adaptability
    Oct 2007
    Default 2JZ-GE engine+gb swap into jzs147 tt aristo adaptability
    hi guys,
    i have a engine-less (originally turbo) jzs147 aristo.
    i now am getting a 2jzge for it (good reason for it), and i want to know a few things from all the guru's.
    firstly, having a distributor setup, will the turbo instrument cluster(i.e the tacho mostly) work with the signal put out from the NA ecu?
    secondly, since i havent seen the non turbo ecu as yet, i want to know, if the aristo's all had trac and abs pinouts in the NA ecu's? if they do, will the signals from trac and ABS put out from the NA ecu, be the same as what would be from the original turbo ECU? im hoping it should be all plug and play..
    hope this makes sense
    thanks for any help !
    Oct 2007
    Default Re: 2JZ-GE engine+gb swap into jzs147 tt aristo adaptability
    spose i should specify that ill be getting a jzs147 ecu to save wiring hassles as well
    Sep 2007
    More trouble then its worth IMO unless you got the engine for nothing id be sourcing another 2JZGTE. Also NA's run the vacuum assist brake booster too.
    Not to mention NA's are worthless compared to the TT variant.
    Oct 2007
    like i said: GOOD REASON FOR IT.
    does anyone have any idea about the tacho, and rectifying the brake booster issue?
    Sep 2007
    Quote Originally Posted by 1jzfanatic View Post
    End up going ahead with the conversion ?
  1. Suspension for JZS147 Aristo
    Last Post: 16-08-2006, 08:52 AM
