Results 16 to 18 of 18
Thread: Ucf11 1Uz Toyota Celsior Error Code 13 Help!
    Default Re: Ucf11 1Uz Toyota Celsior Error Code 13 Help!
    Oh, n i don't speak russian.....
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    May 2010
    Moscow
    Man if only you had even a brief look at that you would see the manuals are english as the menu is (select model/model year). You're really wasting your time a big deal thinking someone would do your work instead of you.
    sorry, for some reason the link didn't show. I'd found this
    http://www.lextreme.com/forums/1uzfe.pdf
    and was rocking through it before you'd posted that link. Hence why i hadn't read through it.
    Anyway - IT'S ALIVE WITH NO CODES! I checked the timing with a timing light. So balancer off (again) marked the balancer at 90 deg, and both cams were running at the same advance. so that ruled that out. Next up i had to re-think everything that i'd done. As a paranoia i checked the crank angle sensor wires and thought that there was a chance that i'd put them on the wrong way (keeping in mind i'd replaced the end of the wires) started it up and hey presto - no error codes!!!!!!!!!!!!!!!!!!!!
    So, that puts that to rest for now. I've still not got any fluids in to see if they leak (other than oil - duh) and i still need thins bloody hydraulic fan hose! Hopefully take it for a spin at least tomorrow. Should be the goods!
    Thanks for the help guys - much appreciated!
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. ucf11 diff code
    By jzx81mx83 in forum Tech and Conversions
    Last Post: 28-04-2009, 07:51 AM
  2. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 12:42 PM
  3. 1G error code 25???
    By amon in forum Tech and Conversions
    Last Post: 03-01-2008, 08:48 PM
