Man if only you had even a brief look at that you would see the manuals are english as the menu is (select model/model year). You're really wasting your time a big deal thinking someone would do your work instead of you.
Oh, n i don't speak russian.....
FJ40 landcruiser
HJ47 landcruiser
FJ55 Landcruiser
MS65 Crown
sorry, for some reason the link didn't show. I'd found this
http://www.lextreme.com/forums/1uzfe.pdf
and was rocking through it before you'd posted that link. Hence why i hadn't read through it.
Anyway - IT'S ALIVE WITH NO CODES! I checked the timing with a timing light. So balancer off (again) marked the balancer at 90 deg, and both cams were running at the same advance. so that ruled that out. Next up i had to re-think everything that i'd done. As a paranoia i checked the crank angle sensor wires and thought that there was a chance that i'd put them on the wrong way (keeping in mind i'd replaced the end of the wires) started it up and hey presto - no error codes!!!!!!!!!!!!!!!!!!!!
So, that puts that to rest for now. I've still not got any fluids in to see if they leak (other than oil - duh) and i still need thins bloody hydraulic fan hose! Hopefully take it for a spin at least tomorrow. Should be the goods!
Thanks for the help guys - much appreciated!
bEn
FJ40 landcruiser
HJ47 landcruiser
FJ55 Landcruiser
MS65 Crown
