Junior Member
Grease Monkey
Re: 1G error code 25???
Thanks for that i will go through that bunch and check them all,that does seem to cover quite a few faults though??
Vacuum sensor where does that live,not TVIS vacuum thingy
i get 55psi rail pressure.
Open Injector circuit how would i check that?
02 sensor is brand new,and the ignition system seems fine(new leads,cap,rotor,etc).
I also dont think its surge as there is a pot
The only symptom form this code is getting on boost up to about 6psi then a considerable dip in power like its running out of fuel,it may have a small back fire and can usualy push on.
This does happen when i stab foot to floor and not so much if i am a little slower with the pedal(not a great deal slower)
this engine is stock except for hybrid T28 single conv,FMIC,pod 3" dump.
I had a feeling it might have been the AFM and are swapping 1 over to see.
anyway thanks again
Guy
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
