Results 16 to 30 of 42
Thread: 4age RWD auto???
    Montrose
    Default Re: 4age RWD auto???
    Sorry, I should say why wouldn't a traumatic FIT - whether it WORKS is another matter!
    Hoppers Crossing
    shinny, were the autos traumatics or a jap spec auto?
    Montrose
    Traumatics... Listen to the racket they make!
    Did these AE71 trimatics have a detachable bellhousing?
    Hmmm. I got the auto out of a Ae71 and it is a Aisin box not a trimatic. Forgot about the 6 Vs 8 bolt pattern tho so now I have to hunt down an Age flexplate
    Banned Grease Monkey
    vic
    doing the same to my car got the auto out of a ae71 and it bolts straight up even the flexplate the only thing im hunting for now is a 8 bolt auto flywheel also the tail shafts are the same length as the five speed but the auto yok is alot bigger
    FYI, on an auto, the flywheel is called a flexplate.
    Quote Originally Posted by allmtr
    Depends if it was AMI or import AE7#. The sedans were made here, the others made offshore. Only local build copped the Trimatic / Borg Warner combo.
    Hmmm. (Part II) The auto was out of a sedan...
    vic
    if the flywheel is called a flexplate then what do you call the flexplate?
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    an "auto flywheel" is called the flexplate. the flywheel is what the clutch bolts onto on manual cars
    vic
    yes all A motors had the a40 not trimatics
    Dave
    and I'm assuming the A40 will take no power
    Any standard 4AC auto box will take no power definelty not the power needed for a 10sec run. You will need a custom bellhousing and a different box however they will weigh heaps and the cost of setting this up will definetly blow you over your 5k budget.
    Aug 2006
    I just bought an auto AE71 and the bloody thing sounds like its going to spit some gears every time it changes to second, i dont know why this is happaning. but untill i pull my finger out and drop the 5sp in is there anything i can do to stop it.
    P.S. when i change to man, auto free to good home if it still works
    Last Post: 17-06-2008, 09:53 PM
  2. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 11:42 PM
  3. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 07:15 PM
  4. 4age engine mounts
    By duff_boy in forum Tech and Conversions
    Last Post: 03-03-2006, 01:35 AM
  5. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 05:51 PM
