Results 61 to 65 of 65
Thread: Turbo Restrictors and Air Cavitation....
  1. #61
    Junior Member Domestic Engineer mic*'s Avatar
    Default Re: Turbo Restrictors and Air Cavitation....
    Volumetric efficiency of piston motor is crap, compared to a rotoary anyway (should read: compared to something i know sweet FA about, and thus should say nothing about )...
    What i would like to know more about is the volumettric efficiency (as per MYNE's definition below) of various 4 stroke piston motors, comparitively.
    Gixer,
    What sort of CFM figures (convert em to LPM for me first if you like ) does for example a SR20 put out at 6000 rpm say?
    Not 6000 LPM be damn sure...
    meh...
  2. #62
    sa
    Um how?
    A rotary, IIRC has 3 chambers per rotor, which is geared UP by necessity so that only 2 chambers are used per revolution of the output shaft.
    So, for every revolution the clutch passes to the gearbox, the rotary is breathing 4 times. That's 2x more than a 4cylinder which can only breath twice.
    So how are you defining volumetric efficiency?
    Should we compare rotaries and 2 stroke 4cylinders? They're on a more even playing feild then.
    Last I checked, volumetric efficiency was the measurement of how much of an engine's maximum induction volume was used. I somehow doubt rotaries are THAT much better than a piston motor if they're both graphed over the entire rev range.
    And then again, you'd have to compare a stock port vs a stock cam, or you'd again ruin the parity.
  3. #63
    lets leave it as the FIA interpretation for high level motorsport.
    although a rotary has twice the displaced volume of a piston motor, it is less efficient, so the multiplier is 1.8 instead of 2 (at least for the older lemans races.. is it still the same now?)
  4. #64
    you were correct, and then incorrect, rotors move at 1/3 crank speed (which is actually the eccentric shaft) so they have 2 power strokes per revolution, same as a 4cyl..
  5. #65
    Sit down, grab a beer and have a read of this thread I wish I'd read it before I sat down and worked it all out for myself....
