Below is a compilation of random thoughts based soley on uneducated genius.
Would, could variable pitch turbo vanes help?
On a helicopter, the pitch of the trailing blade is steeper so that it can get more "traction" with less air to grab. Wouldnt it be nice to have some sort of vacuum advance on the turbine blades?
Obviously there are huge engineering limitations there, but what if the housing inlet itself had fins that directed air in the opposite direction to the turbine. Would that reduce the chances of compressor surge by increasing the energy imposed on the fins?
What I mean is, under normal circumstances the turbo is getting 1 bar of pressure. This pressure has a mass, this mass is more or less just going straight into the blades. There's a deflection force being applied to the air, etc.
When the air pressure is actually a vacuum, could you reduce overspinning by directing the air opposite? The cause of the force is different, but with appropriately angled fins, the effective force might be the same. How that really helps power I'm not sure. I just like thinking.
The only other idea I can think of is to treat the tract between the turbo and the restrictor as a plenum - complete with velocity stacks at both ends.
If you think of it like that, is it possible that each fin creates a similar acoustic resonance to an engine valve? Could there be ways to tune that plenum?
An obvious thought is to make the plenum huge. It'll take a fair bit longer for the air to drop in pressure, which could add valuable extra power between shifts. The shifts, and any throttle lifts would give the plenum time to recover.
On tight tracks, I'd expect this to yeild pretty decent results since you'd constantly be topping up the plenum before it runs out.
Pressurising the air going into the restrictor would be nice too. A big scoop facing forward would add a decent amount at higher speeds I imagine. Probably way too obvious but hey, it's worth mentioning.
So the summary of my ideas : velocity stacks, plenums, variable vane, and resonance tuning.
All normal NA stuff I know, and probably well known in turbo, but a lot of discussion I see seems to treat FI as some totally different beast - like the laws of physics change just because of a fan.
