Results 1 to 6 of 6
Thread: Loose cam cover?
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Default Loose cam cover?
    Might sound like a dumb queston, but does having a loose cam cover(s) affect engine performance at all? Apart from the obvious leaks of oil, will actual engine smoothness, idle, performance etc be effected?
    TA.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Western Aus
    Default Re: Loose cam cover?
    id imagine your oil pressure would be all up to shit?
    Eldar.O.
    S.A
    Unless you have a huge leak ( and i mean HUGE!) it wont effect idle quality at all.
    If the leak was big enough it would be like having the PCV disconected
    Junior Member Grease Monkey stretch's Avatar
    N.S.W
    when i replaced the rocker cover gaskets on a 7m-ge cressida the other day they were leaking real bad and the oil poured straight into the spark plug region, after the oil was in there for a long time the high tension leads became very brittle and lead no.1 actually broke and was causing the engine to missfire. thats just my 2 cents worth mate.
    Eldar.O.
    no dosnt affect oil pressure. only affects blowby pressure.
    and no its fine but becareful you can get nasty oil fires with hot oil on extractors.
    rare but bad.
    Thanks for all the help guys
    Kind Regards,
    Kurt.
  1. help to cover an interior custom door.
    Last Post: 26-05-2006, 11:54 AM
  2. Which 3sg Gen rocker cover is this ?
    Last Post: 10-03-2006, 11:25 AM
  3. Oil mist, cam cover problem
    By BoostBoy in forum Tech and Conversions
    Last Post: 28-02-2006, 07:53 PM
