2nd generation 3sgte out of a 1990-1993 GT4 or MR2.
Can anyone tell me which model and year car this 3sg rocker cover is from? I know the front two humps have been cut off and there is no filler cap due to dry sump setup. I need a set of spark plug leads and every place asks me what model 3sg it is from. There are different length tubes for the plug leads.
Thanks
[Project] 'Bugger' - 1999 Toyota Hilux Turbo Ute - PB: [email protected] 1.857 60FT Video
[Project] 'Red Baron' - 1990 Toyota Celica GT-Four - PB: [email protected] 1.869 60Ft Video
Technical Articles Database 3S-GTE/ST185/Celica - BGB,EPC,Tech || 2RZ/3RZ/5VZ/Hilux - FSM
Thanks for the quick reply Lance. Would you have any recomendations on what leads to use ?
Thanks
Originally Posted by gemtoy
Personally, i'd continue to use the stock toyota leads (brand new ones mind you). They are quite good, but like anything they will eventually perish.
But other then that, most lead makers make leads. Upto you how much you want to spend on leads.
Your pickup sensor for your cam wheel looks interesting!! Got a better dhot of that you'd care to share??
Steve
I like the Magnacore leads, they also sponsor the club which is nice.
On the other hand forget the leads I want to hear more about this dry sump situation. I assume this is being used in a race car. What pump are you using etc? Maybe a members rides thread with some more info is in order I feel![]()
rolleraction - I will take some pics on the weekend.
Joshstix- The engine is going in a Gemini race car. It had a Motor Improvements 3 stage oil pump. Quad throttles custom everything - extractors, twin plate clutch, home made flywheel, 240Z straight cut gearbox.
