I don't think the shift box is faulty as I pulled it off and tested it on a battery with the inputs and it is outputting 12v to each solenoid as it should be.
The solenoid wires do not go back to the std ecu, they have been chopped as has the converter lock up.
So you are saying that you split the crank and cam angle sensors between the stock ecu and the microtech and didn't manualise the auto at all? What other sensors does the stock ecu need?
Chris
