Hi Jess
I rebuild all my own diffs at home. Only tools I use are a tension wrench, dial indicator and a 12mm dia brass punch to remove bearings, a gear/bearing puller to remove centre housing bearings.
Shimming pinion isn't difficult long as you have tooth marking paste or similar.
if your using same gears in same housing shouldn't need to worry to much about shim size, still need to check tooth pattern though. Hardest part is setting pinion preload, may need to put crush tube on peice of pipe and hammer around tube to stretch tube out. I work on feel when setting preload, just feel light pressure when turning pinion flange but won't spin freely.
Once pinion is set just need to set backlash, where I use dial indicator, can be done by feel though then carrier bearing preload.
I rebuilt my last diff April 2011 including replacing clutch packs with thicker plates and use as road car and dirt track car with no noises or problems, using standard TA22 4.1 ratio.
If you have any trouble reply through thread and either I or someone else should reply to help you through.
Regards
Tony
