i have done pretty much what your wanting in my ra40, Im still sorting out all the little things at the moment. but all the info on the ra23/8 to R&P is relevant to ra40. have a good read of the ''RA23/28 with KE70 steering column and rack and pinion'' thread before you do anything. also if you are wanting to keep your 18r you will have to sort out a front sump setup.
the end product for the firewall mount be sure to take care you don't weld upside down using the tabs and hump for reference
before weld , i chose the section at the top of the bearing case to weld because i could apply more weld and make it look stock
