Results 1 to 5 of 5
Thread: Resolving a rough idle and miss once car is warm
    Dec 2009
    Default Resolving a rough idle and miss once car is warm
    Hey all,
    I have a Toyota Caldina ST215 which has the Gen 4 3sgte in it, I have noticed the car has a rough idle and a miss when the cars warmed up.
    The car has sold and I wanted to get it all resolved for the new owner as part of the sale.
    I changed the plugs recently, but they were gapped correctly as speced by Toyota.
    I know the car has a VAIC valve which controls the air intake, I am wondering if the miss could be caused by a low idle of around 500-600rpm.
    Any advice would be fantastic, thanks in advance
    New South Wales
    Default Re: Resolving a rough idle and miss once car is warm
    Yeah id do a step by step process, start with the easier ones first
    check (all) the plugs, see if the engine is running rich, if so then check all the wiring around the ignition side (no broken wires, loose plugs)
    with that valve, have the engine at running temperature and there might be a hole just in front of the throttle, place ur finger over the hole and n feel if there is any vacum. there shouldnt be when the engine is warmed up. if that the 3sgte is designed that way.
    or even maybe just bring up the idle at the idle screw.
    Dec 2009
    Quote Originally Posted by Muzza View Post
    Thanks for all the suggestions Muzza,
    I'll do bit by bit to see what could be causing it. I have a feeling it could well be the idle. I would have thought that with the car having one of those idle speed control valves that there wouldn't be an overide.
    Could the other choice be raising up the idle from the bolt on the throttle body that limits/changes the default position of the throttle body.
    New South Wales
    what does your engine idle a during warm up?
    yeah have a go with the idle screw to raise the idle a bit.
    Dec 2009
    It doesn't seem to miss (or as noticable) when its warmed up so it could well be that the motor is having trouble sustaining a reasonable idle due to the revs. It really does sound too low.
    Thanks
  1. Issue with 5me running rough when warm
    By Blair in forum Tech and Conversions
    Last Post: 18-03-2011, 04:25 PM
  2. EDIT: 1jz runs rough when warm!! help
    By Azzamk2 in forum Tech and Conversions
    Last Post: 23-02-2011, 09:09 AM
  3. The bastard 3S smokey at warm idle
    By ONCE-NA in forum Tech and Conversions
    Last Post: 02-10-2007, 10:10 AM
  4. 1uz warm up/idle
    By Aphox in forum Tech and Conversions
    Last Post: 02-07-2007, 04:25 PM
  5. 20v Idle problems when engine temp is warm.
    By 2revup in forum Tech and Conversions
    Last Post: 29-03-2006, 12:47 PM
