Results 16 to 22 of 22
Thread: 180+ hp 4AGE running cost ?
    Mar 2011
    Beograd
    Default Re: 180+ hp 4AGE running cost ?
    It clearly says 4AGE in title.
    Not 7AGE, not 3SGE, not even C20XE, Duratec, M10...
    I know, I read it- I am just curious why
    I am guessing it's another one those things I don't get because I have different things influence my choices
    Mar 2011
    Beograd
    - like the 4AGE way it is
    - keeping it in a way that i can do some hillclimbing/racing in FIA 1600ccm E1 class
    - like to succed in things that are not that easy
    Slamming in 3SGE sounds easy, at least for me. I wouldn't buy AE86 if i wanted it to be easy. In that case i would buy BMW E30 and put in 2.5 24v or 3.5 12v. Nope, don't like it .
    Well if it's to suit a class then that's another story.
    What hasn't been mentioned before is there are some reports of the stock pump breaking up at higher revs. How much truth is in it I don't know.
    I guess this also comes down to 16 or 20V?
    Jan 2012
    Finland
    First;the stock head flow enough for about 180 hp and may produce it if everything else is right.Most tuning cams are made for stock heads that quit at 8 mm lift.
    Even mild porting needs camlift around 10 mm (being 210 hp territory) and serious engines more than that.Those 220-240 hp engines have cams with 12 mm lift(or more).What kind of running cost of 180 hp 4A-GE? Depends how it's done but what the 170 hp 20v Blacktop needs? Basic maintenance and that's it!
    Basically same engine and if it is used as street engine the street engine rules apply.You drive hard;you pay attention to engine..
    oregon
    Quote Originally Posted by uzelac View Post
    Hey, thanks, but as i said, i know what engine parts make that power
    I'm interested what after you make that kind of 4AGE.
    From what i know:
    I can get access to the original camshaft grinds that Toyota used for their race ae86 before and after they where told not to use shim under buckets.
  1. Help needed with 20V 4AGE running lean.
    By ScreamingHeap in forum Tech and Conversions
    Last Post: 09-08-2011, 07:23 AM
  2. 4age not running when up to temp
    By scottbeaker in forum Tech and Conversions
    Last Post: 08-06-2009, 10:32 AM
  3. 4AGE 16V Running Poorly
    By SIC86 in forum Tech and Conversions
    Last Post: 09-03-2006, 07:35 AM
