Results 16 to 30 of 42
Thread: problem with throttle !!!!!!!!!!!!!!!!
    Dec 2011
    BC
    Default Re: problem with throttle !!!!!!!!!!!!!!!!
    allrigth im on the page so the vpa and vpa 2 are the tps but were the motor for the throttle?
    Dec 2011
    BC
    is vta and vta2 the motor?
    No that is the throttle position sensor. Motor is CL+ CL- M+and M-
    Jealousy is a curse
    Dec 2011
    BC
    alrigth yes we got every thing conected probably the gears or the magnetic clutch on the liltle motor are stuck because my friends told me that they actually hear the motor trying to move
    you should be able to manually move the butterfly with the intake pipe removed
    Jealousy is a curse
    Dec 2011
    BC
    yes it does move but its still in limp mode prrobably there a problem with the magnetic clutch
    Dec 2011
    BC
    or probably because the maf is missing
    What error codes do you get?
    Jealousy is a curse
    Nov 2011
    he is better of wiring up the obd2 plug and getting live data
    plug a scanner into it and u can get heaps of info
    Dec 2011
    BC
    it never came with the obd2 plug im screw.......
    or probably is the litle motor that its not workin
    Quote Originally Posted by dumbass View Post
    It is not your usual OBD2. He is better off reading the error codes
    Jealousy is a curse
    Dec 2011
    BC
    on the dash right?
    Nov 2011
    prob no ecu light hooked up
    Yes, off the dash, or the diag box. The W pin drives these both.
    Connect Tc to E1 (ground) and the codes should come out on the check engine light and w pin
    Wilbo's JZA80
    Wilbo's JZZ12
    Dec 2011
    BC
    ok so its working when ignition on but when we start the engine it stops working............what did every one did with the abs trc does it afect the engine performance?
  1. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 06:43 PM
  2. 1jz 1/4 throttle same as full throttle?
    By naten in forum Tech and Conversions
    Last Post: 08-12-2007, 12:03 AM
  3. 4ag throttle
    By joe90 in forum Tech and Conversions
    Last Post: 14-07-2006, 06:38 PM
