Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Thread: problem with throttle !!!!!!!!!!!!!!!!
    Nov 2011
    Default Re: problem with throttle !!!!!!!!!!!!!!!!
    i remove those wires and never had any probs
    u got yr ecu light working and tested for codes yet?
    Dec 2011
    BC
    migth conected tomorrow i have a question does the electronic throttle has to do something with the fuel managment?
    and i have a idea i can get a non electronic throttle for the 1jz if a change the thrrottle is it nesesary to change the ecu?
    Nov 2011
    yer its not to big a job
    piss of the electronic throttle body
    run a cable throttle
    cut the ecu plugs off
    wire in a motec or autronic or link eci
    get it tuned
    all sorted
    Quote Originally Posted by dumbass View Post
    get it tuned
    all sorted
    exactly how I modified my 2jz-gte vvti
    Nov 2011
    bring it here and ill get yr progblem sorted
    hehehehe
    Dec 2011
    BC
    ok i got the codes guys its code 31,46,62,63,65,68,75,76,77,89
    31 is airflow meter problem
    75 is power steering pressure sensor problem
    89 is throttle control motor/circuit malfunction
    rest are automatic transmission codes
    fix 31 and 89 and you will be cackling
    Jealousy is a curse
  8. #38
    Dec 2011
    BC
    allrigth we got the engine runing the only problem is the throttle motor is not working so were gonna try and go manual on the throttle valve will post some pics later on
  9. #39
    Will not cure your air flow meter problem
    Jealousy is a curse
  10. #40
    Dec 2011
    BC
    i conected the rigth maf and no more codes for now
  11. #41
    Nov 2011
    i doubt u will fix anything if u got manual throttle
    fly by wire is pretty anal with tps signals
    anyway maybe it might work
  12. #42
    Dec 2011
    BC
    so the cars is runing now but we got another problem when i go all the way in the gas pedal like all of the sudden and it starts to build boost,the engine turns off and in order to turn on the engine again i have to turn the key off and then on again any help!!
  1. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 06:43 PM
  2. 1jz 1/4 throttle same as full throttle?
    By naten in forum Tech and Conversions
    Last Post: 08-12-2007, 12:03 AM
  3. 4ag throttle
    By joe90 in forum Tech and Conversions
    Last Post: 14-07-2006, 06:38 PM
