is vta and vta2 the motor?
allrigth im on the page so the vpa and vpa 2 are the tps but were the motor for the throttle?
No that is the throttle position sensor. Motor is CL+ CL- M+and M-
Jealousy is a curse
alrigth yes we got every thing conected probably the gears or the magnetic clutch on the liltle motor are stuck because my friends told me that they actually hear the motor trying to move
you should be able to manually move the butterfly with the intake pipe removed
Jealousy is a curse
yes it does move but its still in limp mode prrobably there a problem with the magnetic clutch
or probably because the maf is missing
What error codes do you get?
Jealousy is a curse
he is better of wiring up the obd2 plug and getting live data
plug a scanner into it and u can get heaps of info
it never came with the obd2 plug im screw.......
or probably is the litle motor that its not workin
on the dash right?
prob no ecu light hooked up
Yes, off the dash, or the diag box. The W pin drives these both.
Connect Tc to E1 (ground) and the codes should come out on the check engine light and w pin
ok so its working when ignition on but when we start the engine it stops working............what did every one did with the abs trc does it afect the engine performance?
