Results 16 to 30 of 32
Thread: 4AGE 16-20v Mods/Interchangeable parts
    perth
    Default Re: 4AGE 16-20v Mods/Interchangeable parts
    carbs and manifold have shorter runners, the carby manifold will run a bit cooler and has proper velocity stacks.
    Jul 2007
    Quote Originally Posted by oldeskewltoy View Post
    My 1987 AE86 came with a 7 rib block, and 40mm internals......
    interesting. late 86 early 87 is when the 7 rib was phased in, could be you got a bitsa from the factory? it's been known to happen with models where the changeover ones had a bit of series 1 and series 2 components, not hard to stretch that to engines...
    Either way the toyota EPC shows the part number for the crank is the same for all 7 rib blocks (bigport, smallport, silvertop, blacktop etc) so unless you happen to be especially lucky, as OST seems to be here, then you can generally take it as a pretty decent rule of thumb to follow.
    Quote Originally Posted by fixeruperer View Post
    Nothing a set of ITBs wouldn't solve...
    perth
    yeh but that wasnt in the swap.
    I know, just pointing out that you could get most of the benefits of going to carbs whilst still keeping the best bits of EFI, and probably with less hassle and cost too
    Nov 2011
    Luzo
    well.... just to be a PITA...... and to prove that information accuracy isn't always what we are told......
    Oh and it was the original engine... you see it had the VIN tag riveted to the block
    Oh... silvertop pistons are pretty crappy overall, pop a set of smallport pistons in, do a bit of porting, cut the head about .020"(1/2mm) and you are good to go....
    Thanks bro for the advice.. i'll take note of that .020"(1/2mm).. problem now is sourcing out for sp piston set and also will i still be using my stock crank assembly?
    Nov 2011
    Luzo
    is this based on experience?
    Nov 2011
    Luzo
    Quote Originally Posted by Sam_Q View Post
    flywheel fit's straight on if you have the matching clutch.
    You will probably not gain that much of a compression ratio raise with the 20V pistons due to the fact that the silvertop chamber is smaller.
    Besides if you have a bigport none of this stuff would fit as it has a different crank
    no wondering why my XTD stage3 clutch kit wont fit with the stock 16v BP flywheel. but it say's in the package that it's for 1.6 1994 corolla
    here's the actual image:
    so with the blacktop or silvertop flywheel, this clutch will fit in? as well as with the stock 4AC tranny?
    oregon
    Feb 1987 was the build date. I no longer own that car... and even if I did, that was the original engine... I swapped it out for a silvertop, with 16V high comp pistons, a mild set of cams and the rest was rwd AFM TVIS. I had her for over 10 years. Anyway, the original engine was sold off as my wife and I decided to move west. So my original 7 rib with 40/18 internals is somewhere on the east coast of the USA
    perth
    Quote Originally Posted by celicaJZ View Post
    yes, but my experience wasnt with the 4ag.
    Nov 2011
    Luzo
    so you think there's more gain and in power and acceleration if i switch to carbs? 45 webers.
    perth
    the top end will benefit but is it worth it ? i dont know.
    Jul 2007
    it will be slower pretty much everywhere compared to a good efi setup with ITBs and ram tubes etc
    celicaJZ: that's probably for a 212mm flywheel when you have a 200mm. A smallport or 20v flywheel is what I am guessing you need. Measure the diameter of the friction surface
    perth
    oh im sorry, i must of missed the part when he said he has a good efi sytem with tuned length runners and ram tubes.
    oh he didnt ? anything else you wanna add ?
  1. 13T engine parts interchangeable in 2T?
    By st.celica in forum Tech and Conversions
    Last Post: 09-09-2010, 10:55 PM
  2. 4AGE dizzy interchangeable
    By L4AGZE in forum Tech and Conversions
    Last Post: 16-08-2010, 09:53 AM
  3. Ra23 -> Ra28 - Interchangeable Parts
    By twentyEight in forum Tech and Conversions
    Last Post: 24-10-2006, 12:56 AM
  4. 4age oil cap interchangeable with ?
    Last Post: 13-07-2006, 05:42 PM
