Results 1 to 4 of 4
Thread: 4AGE dizzy interchangeable
    Jan 2008
    Manchester, England M33 6HE
    Default 4AGE dizzy interchangeable
    I've got a bit of a problem at the moment with my 1987 AE92 GTi (UK model). As a process of elimination i am looking to change the dizzy with another one and as these are not the easiest to source was wondering if the dizzys are interchangeable across the 4AGE range. Obviously there was the blue top then red top and also the later 4AGE engines. The EPC shows different part numbers but that is for the complete assembly and they all had different dizzy caps and leads anyway.
    Default Re: 4AGE dizzy interchangeable
    Mechanically they are the same, plugs are different and i think there may be some electical differences also, based on my experience converting a Smallport engine running Bogport ECU, Injectors and dizzy to the proper stuff.
    What is the problem you are having? there are things you can check to see if the dizzy is ok.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    queensland
    there are 3 totally different dissys. the 2 bolts that hold the cap are in a different location, electrically different also. you need the correct one.
    Jan 2008
    Here is a much earlier post with the symptoms i am having. I had left the car for months now going back to it hopefully
    http://www.toymods.org.au/forums/showthread.php?t=56006
    Looking back on it maybe i should start with the starter again but now im thinking alternator maybe..
  1. 4age oil cap interchangeable with ?
    Last Post: 13-07-2006, 05:42 PM
