Originally Posted by
Thirteen13
1. When cold start/first start of the day: motor seems to miss, pop and fart around. It will only do it till the motor gets to around 40-50c then its fine and nothing is wrong
2. When the OverTemp Fan settings kicks in the motor is obviously quite hot and will usually happen in slow moving built up traffic, and the motor drops a few hundred RPM but then at times when you take off it seems like its flooded and when u take off the motor sounds like its drowned and the rev die right off and will either stall. Then do an FC restart and see lots of fuel smoke out the back, or manage to get the revs up enough to clear out the fuel.
