Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: wolf 3d to 1jz-gte
    Default wolf 3d to 1jz-gte
    Urgent!
    Jzz30 ecu, ne – and ne are red and yellow. (crank angle sensor) Which one is which? I have the ecu pinouts but no colours.
    I have a jzx90 ecu which is different and the ne – and ne are white and orange.
    Thanks!
    Chris
    instant rep to whoever helps!
    QUICKEST 1JZ'S IN OZ
    Default Re: jzz30 crank angle sensor colours? *urgent*
    I'd be using Red as +ve.
    ok, thanks mate
    Next question:
    Anyone know what colour wires are on igt1-6 on a jzz30 ecu? I have a wiring diagram for the jzz30 to wolf but can't read the wire colours because they are so small.
    Alternatively, if you know what cylinders go to what igt output from the wolf (waste spark) So would it be, igt 1 to igt 1&6, igt 2 to igt 2&5, igt 3 to igt 3&4. That is what I think it should be.
    Don't you still have the factory JZZ30 ecu plugs still attached?
    i have a jzx90 engine.
    I have wiring diagram with very hard to read colours and it doesn't have igt1-6 named.
    I am pretty sure the colours on the jzx90 are different to jzz30. So I can either find out the colours to the jzz30 and then work out which cylinder goes with which.
    Or if someone already knows that, then I have labelled my 1gt1-6 and I just need to know which ones to pair up
    Thanks
    You have seen this?
    yep, got that one. that is jzz30.
    I have the one for my jzx90 engine (same as jza70). But need to know which cylinders to connect the igt 1-3 from the wolf to
    Umm, JZZ30 is the same as JZX90
    not a chance. jzx90 is the same as jzx81 and jza70 according to http://www.supraforums.com.au/forum/...ad.php?t=16598
    and that jzz30 pinout is definitely not the same as mine. Mine is this one http://www.1jz-gte.us/Images/TSRM%20...1ecupinout.jpg
    Junior Member Backyard Mechanic manny's Avatar
    jzz30 and jzx90 are pin/plug compatible and I believe jzx81 and jza70 are pin/plug compatible - if yours is like a jza70, are you sure it's not a jzx81 loom you've got?
    If it's got a pigtail, it's an jza70 Supra or jzx81 Chaser loom.
    GSE20 IS250 - daily
    I'm with Manny.
    The age of the cars suggests JZX81 and JZA70 are the same, and JZZ30 and JZX90 are the same.
    I've never heard anyone say JZX90 is the same as JZX81
    I have the jzx90 dash in my car and that came from the halfcut so it must be jzx90.
    All I know is that http://www.1jz-gte.us/Images/TSRM%20...1ecupinout.jpg is definitely my ecu and the other one that Cruz posted is not mine.
    It doesn't really matter what I have except the wiring diagram I have has the colours for a jzz30. This is the diagram http://soarercentral.com/sc-forum/me...ng_3-46569.pdf
    and this http://soarercentral.com/sc-forum/me...ng_3-46569.pdf
    has the 3rd and the 6th as the same R-B????
    Your ECU pictured on sf.com.au left the factory on an auto JZA70 Supra.
    A few ECU Part numbers I had here for reference-
    1JZGTE from JZX90 Chaser M/T 89661-22480
    1JZGTE from JZX90 Chaser A/T 89661-22470
    1JZGTE from JZA70 Supra A/T 89661-22400
    GSE20 IS250 - daily
    Good question. Wire it up guessing, and if it runs rough, swap it over.
    You wont do any harm wiring it wrong.
  1. 5sfe crank + 3sge = 5sge?
    By NeoNasty in forum Tech and Conversions
    Last Post: 19-04-2007, 09:18 PM
  2. 4ag crank pulley sizes
    By benjamin in forum Tech and Conversions
    Last Post: 08-02-2006, 06:27 PM
