Results 1 to 4 of 4
Thread: 1mz-fe cam pulley bolt removal
    Default 1mz-fe cam pulley bolt removal
    hi all,
    I've been trying to remove the front cam pulley bolt on my camry but without access to a (good) rattle gun its staying put
    tried using a spanner (15/16" attached to a pipe) on the cam and a breaker bar (attached to a pipe) on the bolt but the spanner always "climbs up" the cam and now the thing on the cam is slightly burred.
    i've heard that using the SST / spanner wrench can damage the pulley..
    are there any other tools to lock the cams, or should i just give up and take it to someone to loosen the bolt?
    Quote Originally Posted by rob
    but if i run a cat on my 4K-C ill only have 3hp instead of 4hp
    wa
    Default Re: 1mz-fe cam pulley bolt removal
    Quote Originally Posted by 2jzhilux View Post
    any chance of damaging the pulley with one of these?
    i'll have to try and grab one tomorrow, thanks
    wa
    It grips on the inside of the pulley so it wont damage it, have used them on 1mz's heaps of times (like 100+) but it will be real tight, dont be scared to break the pulley ..it wont.
  1. Help with 1JZ Harmonic Balancer bolt removal
    By Herus in forum Tech and Conversions
    Last Post: 04-07-2010, 10:33 AM
  2. Broken bolt removal services
    By HighLife in forum Tech and Conversions
    Last Post: 01-06-2008, 01:20 AM
  3. 5-ME crankshaft pulley bolt
    By GasedT18 in forum Tech and Conversions
    Last Post: 31-12-2006, 12:21 PM
  4. 2jz crank pulley bolt removal
    By Draven in forum Tech and Conversions
    Last Post: 02-07-2006, 04:01 PM
