Have you tried opening up the ecu to check if the pins are labelled?
Also, this would probably have similar wiring to the 18RGEU, which there is info on in these forums.
What igniter and coil do you have?
Hi i have a 81 hilux 4x4 had the old 18R now putting in the 22RE. i have looked all over the net and cant find the info i am looking for. i have the old 2 plug ECU and every thing i do find seems to be incomplete. like the one below, can eny one fill in the gaps or tell me if it is wrong?
01 02 03 04 05 06 07 08 09
10 11 12 13 14 15 16 17 18 TURNS OUT THEASE ARE ALL OVER THE PLACE !
01 IG, RPM signal from ignitor
02 E3, Ground
03 W, CEL
04 B+, Switched Power
05 -? , ???
06 -? , ???
07 -? , ???
08 -? , ???
09 -? , ???
10 E2, Ground
11 VS, AFM flap opening
12 VC, Power to AFM
13 BATT, Battery power
14 THA, Air intake temperature
15 B/K, Stop light switch
16 STA, Start signal (neutral start switch?)
17 A/C, Air conditioning idle up VSV
18 OX, Oxygen sensor
01 02 03 04 05 06
07 08 09 10 11 12
01 E1, Ground
02 TL, TPS (WOT)
03 PSW, TPS (power)
04 -?, ??
05 20, Injector output
06 E02, Ground
07 THW, Water temperature
08 IDL, TPS (Idle)
09 VF, Diagnostic plug
10 T, Diagnostic plug
11 10, Injector output
12 E01, Ground
As viewed looking at the AFM:
01 FC , ??
02 E1 , ??
03 E2 , ??
04 VB , ??
05 VC , RUN THIS TO SAME PIN ON COMPUTER ???
06 VS , RUN THIS TO SAME PIN ON COMPUTER ??
07 THA , RUN THIS TO SAME PIN ON COMPUTER ??
ALSO CAN ENY ONE TELL ME WHAT THE PICOUTS ARE ON THE IGMIGHTER/COIL??
If they're of help, I have a several wiring diagrams from 22RE cars (for older mechanical/vacuum-advance ignition system and the later ECU-controlled ignition system). PM me an email address and I'll send you a bunch of PDFs.
I did decode some of the pins on the ECU plugs, but mostly to work out how the ECU connected to the chassis loom.
Those can be found here: https://spreadsheets.google.com/spre...2c&output=html
Just a side note, you may want to check the CAPS CONTROL. It appears it might be broken too.
Thanks for the info my email is [email protected], will open up the case of the ecu today ( can only work on it on the weekend )
81 Hilux sc, locked,lifted,37's, Soon to come 22RE
You are running a 22R loom right?
And just quickly, the 18 pin plug is referee to as "A" and the 12 pin as "B" .....
So:
A5: intake air temp. Sensor
A6: n/a
A7: start signal
A8: brake pedal signal
A9: n/a
B4: diagnostic test terminal.
I have HEAPS of wiring info for this engine, I'm just trying to go through it all....
Thats all good info keep it comeing and do i have to run all thease wires to something or can i leave some out ???
I have opend the computer and the pins are
looking into the ECU
01, E2, ground
02, VS, AFM flap opening
03, VC, power to AFM
04, BATT, battery power
05, THA, Air intake temperature
06, --- BLANK
07, STA, Start signal (neutral start switch?)
08, A/C, Air conditioning idle up VSV
09, NS,
10, IG, RPM signal from ignitor, DOES ENY ONE NO WHAT WIRE IS THE OUTPUT FROM THE IGNITOR ??
11, E3, ground
12, W, CEL
13, +B, SWITCHED POWER
14, --- BLANK
15, SPD,
16, --- BLANK
17, EGR,
18, SD,
this part of the loom is all intact but is thir eny thing i should look out for ??
01 02 03 04 05 06
07 08 09 10 11 12
01, THW, water temp
02, IDL, TPS idle?
03, VF, Diagnostic plug??
04, T, Diagnostic plug??
05, #10, injector output
06, E01, ground
07, E1 , ground
08, TL, TPS (wot)
09, SW,
10, ---BLANK
11, #20
12, E02
01 FC , ??
02 E1 , ??
03 E2 , ??
04 VB , ??
i have the factory coil and igniter and the dizzy has realy thin leads? thare are 2 pins out of the coil. and 2 out of the ignighter. power and ground???
can i burn it out if i wire it up wrong??
