...i could write a whole encyclopedia on the answers but use the search functions and just look for related threads and you should find what you are looking for. Questions like yours get asked every other week so there is definitely plenty of info out there.
First question - what are you plans for the car / engine / suspension. This all governs what you will get for the money you want to spend. Is the car for road use only, occasional track days or future serious upgrades?
Q1 - Weber 32/36 with an adaptor plate. Should be able to find one for $150-$200. Fits std manifold. Easy to tune and uses original linkages for the throttle.
Q2 - LSD is exxy or hard to swap to a non std type. Why the need anyway with a 2T. If you get the handling right you shouldn't be doing too many single spinners.
Q3 - Cheap front end upgrade is Kings / Lovells lowered springs, KYB or Koni shocks on RT132 or XT130 front struts and brakes. Whiteline heavy duty front sway bar also needs to go in. These should all be bolt in without the need for coilovers etc. Put some decent shocks in the rear and leave the rear sway bar off to allow for a little bit of roll and tyre contact with the road.
Do all this and you will have a reasonably nice driveable car at $1200 - $1500 depending on how much of this you can get 2nd hand.
