Just be aware when looking at dry sumps, the 16V version wont fit the 20V block. Will find the details and post shortly.
Callum
Dry sump setups typically don't use windage trays, only crank scrapers.Originally Posted by oldcorollas
(Gone for three weeks on a 4WD trip, starting right now. Catch ya when I get back guys)
Callum
Originally Posted by Jimtune
Originally Posted by WDE_BDY
Thats from a guy successfully running an Atlantic spec engine in his Starlet in NZ.Originally Posted by Jimtune
Callum
yah, on the yahoo ad, they also mention the 16V sump not fitting on the 20V... they also mention that the RWD mounts may interfere with that pump too..
Late 16v blocks are the same as 20v. The recess is due top 4wd setup...
Old toys for old boys
interesting !!
will have to get some comparo pics up!
so anyway, i found this on yahoo auctionsand remembered this thread...
http://page11.auctions.yahoo.co.jp/jp/auction/n51031742
supposedly from N2 series? looks very solid!!
worth a buy perhaps? or a copy? just for high rpm or also for high boost?
around $250 so far...
what would something liek this cost to machine up?
edit., it's an SS works one i put on last page, retail is $1100-1200![]()
(uploaded for when yahoo pics go down)
If you design it in CAD, and supply material... then about $400. About 30 mins of programming, then 90mins of CNC time depending on machine capabilities.Originally Posted by oldcorollas
Then extra ones at probably $300 each as the hard work (programming) is done.
so similar to the $500-550 it went for then? (but half the original RRP)
As with anything made on the CNC mills, the more you make the cheaper it gets. If you wanted 10, it would more like $250 each. Operator doesn't have to change programs etc, so its more efficient. Plus they could do 4 at a time on a largish machining centre.
Quite often some of your biggest costs is the downtime between jobs. Setting up the billet takes a bit of time.
Also your material costs are a lot less if you are buying more.
A typical single piece of 6000 series billet about 200x400x60mm would be around $80. If you bought 1000x800x60, it would be less than $800 if you know what I mean.
I'm sure if you were prepared to invest a bit of cash you'd make a tidy return on them if you could sell them for around $500 each.
The biggest bit there would be having someone who knew their way around a good CAD program, and also had all the dimensions and specs on-hand to actually draw the thing in the first place. That'd be a fair bit of time and money, unless you could do it yourself/knew someone. I could organise for something like this to be done, but it would cost a fair bit (mind you, spectrals estimates don't sound too far off), if there was a market for it...
RM.
Its not a difficult piece to design in CAD. The tricky part would be getting the dimensions. The height of the extruded section to bolt to the top of the mains caps would be a difficult one to measure. The cutout for the crank throw as well. The rest would be pretty easy.
Oh and the extended mains bolts wouldn't be cheap either .. so thats another cost
Getting back ontopic.... I'd think that unless class rules prohibit it, if you need to go to these lengths to get a motor to produce ~200Hp... then its time for more cubes or boost. 3SGE can usually be fitted where a 4AGE would normally resides.
Or if it was for my clubman, I'd go straight for the Hayabusa engine![]()
Spewin i didnt
Spewin i didnt see that earlier !!!! I would have snapped that up for sure !!
