After reading this thread with interest, and having both PRB compisite body and numerous 4AGE engined cars , some points to ponder.
1, you dont need 9000 rpm to have fun in a clubman sports, mine is 20v with ford type 9 close ratio g/box, haltech ecu. like a big go kart.
0 to 100 in under 5 secs try that in a normal car (read normal)
2 ,This 4age was built in 2001 and has been thrashed by 25 year old son since ,93rwkw at dyno day 9, last run at JEM with 92rwkw, you need to following.
20v oil pump,chev rod bolts on 100kw (ae92) rods plus peened
forged pistons, dont even try std toyota pistons
good oil cooler,fair dinkum extractors (trd or same) 4/2/1
crank angle sensor from gze with coil packs,
quads need 45 mm at least so will need to go for black top or after market,
head needs to be cleaned up a fair bit in the ports etc,
cams are new camtech billets , think they are 293 with 8mm lift and still using std lifter.
std valve size,springs are of the trd vareity with new retainers
comp ratio allows it to use mobil synergy 8000.
yea and still in 3 rib block.
only thing he does on a regular basis is change oil every 4000 k and let motor warm up throughly before driving.
(or it was the dyno but it was a dyno dynamics dyno)
