Results 1 to 8 of 8
Thread: Options for a fuel pump setup 4AGE 20V engine upgrade
    Aug 2009
    Aruba Dutch Caribbean Islands
    Question Options for a fuel pump setup 4AGE 20V engine upgrade
    Hi, I was wondering if any body has an idea for a fuel pump upgrade when in need of more fuel. By this I mean the installation for a bigger in tank fuel pump. Any of you has made a some sort of bracket or have other options? I'm upgrading my 4AGE 20v engine to a turbo setup with bigger injectors and more fuel is necessary . I have the engine in a Corolla AE86. Thanks in advance for any help and ideas.
    May 2006
    Default Re: Options for a fuel pump setup 4AGE 20V engine upgrade
    Walbro 255 LPH in tanks are a cheap and seem work fine. Easy fitment in a baffled AE86 tank too.
    Aug 2009
    Question Re: Options for a fuel pump setup 4AGE 20V engine upgrade
    Quote Originally Posted by beerhead View Post
    Thanks for the reply beerhead. I have a new Denso fuel pump already but needs fitment. Problem is the car was a carburated engine car and didn't have an in tank fuel pump. Do you know how to make a bracket for the AE86 fuel tank or do you know of any other bracket that will fit?
    oregon
    replacement tanks are under $140.00 @ Rock Auto ( http://www.rockauto.com/catalog/moreinfo.php?pk=17816 ). Not knowing if you have Rock auto... you might try one of many local parts places to see if you can purchase a GT-S tank
    Aug 2009
    Quote Originally Posted by oldeskewltoy View Post
    Do you have an idea how I can make a bracket for the in tank fuel pump since this was a carburated car and didn't have an in tank fuel pump before.
    Quote Originally Posted by ArubaAe86 View Post
    Pull out the sender unit and cable tie a walbo to the stork?
    Or run a lift pump into a surge tank then a main feed pump.
    victoria
    since we are on the topic and dont see the need to start a new topic for it, how the hell do u get that retainer onto the walbro pump?? that small metal thing to hold the filter onto the pump. cant seem to make it fit
    4+4=8
    4 cylinders + 4 throttles = V8 like noise
    Sep 2010
    When in doubt of an intake install, I usually leave the intank in place and run something like a bosch 044 inline to the original.
    This has been how ive gotten out of EFI conversions in the past.
  1. 1G-GTE fuel pump upgrade...
    By GZ.20.GT in forum Tech and Conversions
    Last Post: 10-10-2010, 07:58 PM
  2. 4age valve upgrade options
    Last Post: 14-07-2010, 11:50 AM
  3. Do i need to upgrade my fuel pump ?? See inside
    By slydin-cressy-style in forum Tech and Conversions
    Last Post: 19-06-2008, 04:33 PM
  4. ae82 fuel pump setup into sprinter?
    By s2k in forum Tech and Conversions
    Last Post: 04-12-2007, 02:49 PM
  5. bosch fuel pump setup..
    By renxun in forum Tech and Conversions
    Last Post: 08-03-2007, 03:12 AM
