Hi Myne,
Quoting one of my post from a while ago, that nobody really answered at that time....
The 30.5mm valves would be heavier (but better with exotic material maybe) , requiring heavier springs = more wear. Maybe there would be less 'meat' to heatsink the spark plug area into head, maybe it would be weaker - I guess you could ceramic coat. Might be harder for air to get past the valves if they get too close to the cylinder wall (is that called shrouding?) Would there be enough meat in the head (before water jacket) to bore the area behind the valve out to 30mm also?The exhaust port on my 4AGZE is 30mm, and the exhaust valves are 25mm.
The area of 2 x 25mm valves is equivalent to 35mm circle but is this relevant? The actual open area, converted to an equivalent diameter would be SQRT( 25dia x 8mm lift) = equivalent to a 28mm hole, so two of these = 39.6mm hole. Now obviously this is completely ignorant of any fluid dynamics but are there calculations useful? Does this mean my exhaust port is the limitting factor? (assuming my engine had enough air going through it in the first place)
FYI : The formula atlantic valves are 27.5mm (though I have seen you can get 28mm).
Cheers, Nick
