Hehe, I knew you'd end up ducking down to Odins and finding something like that
 Re: SuperPro Bush install - xA6x IRS Swing Arms
				To be precise
Yes, I could have gotten something made up to the specs I wanted, but these were there, and cost me $15.
				Superpro know about it and should be making up a set of bushes that are right.
I dropped in a rear arm and subframe last week (and they still managed to fuck up the bushed that they gave me after I told them about 7 times what they needed to do the idiots) and they took measurements etc.
Nolathane also do not list the right part number or have something that will fit.
Noltec bushes fit to my knowledge (they at least list dif part numbers for the outer and inner).
				Thanks for dropping that in Wilbo, hopefully by the time I get around to getting the bloody bushes, they'll be alright
				No woz, I also talked to Nolathane about them stuffing up(so they know about it now).
Superpro made up the correct crush tubes (the metal part that the M12 goes through), but they didn't shorten the bush enough! (because the idiots slapped BOTH the bushes maked inner; which are thinner, on the outer bush location and just assumed that the two thicked bushes marked outer would work for the inner *BZZZZ*...not happy jan springs to mind, the arms were pretty well impossiable to install with the wider bushes (I rearranged it so that the outer bush was the wider one-> put the bushes in as they should have been).
I'll be chasing it up at anyrate and will kepp you updated / let you know when the finially get it right!
