Results 1 to 13 of 13
Thread: MA61 Noltec and SuperPro Bushes: PN#'s and $$$
    Penrith BC
    Default MA61 Noltec and SuperPro Bushes: PN#'s and $$$
    Noltec: 02 9980 9777
    http://www.noltec.com.au/
    MA61 Noltec Urethane bushes
    NOTE: Prices are over the phone quotes from Noltec Direct, and are JUST A GUIDE
    Control Arm Inner (FRONT) N51665 $34+ tax
    Radius Arm (FRONT) N51665 $37+ tax
    Control Arm Inner (REAR) N61666 $70+ tax
    Control Arm Outer (REAR) N61667 $82+ tax
    SuperPro Urethane Bushes:
    http://www.bac.com.au/
    NOTE various prices available, depends who you speak to. below are JUST A GUIDE
    Front Control Arm Lower - Inner Bush SPF0509K $24.5 Use original shell 2B,2T
    Front Strut Bar To Chassis Mount SPF0307K $25.5 4B
    Front Sway Bar Link Bush Kit SPF0903K $13.5 8B
    Front Sway Bar Mount To Chassis Bush SPF1450K $10 Measure bar dia 12-30mm available 2B
    Rear Control Arm - Inner Bush SPF1213K $55 [IRS] 8B,4T
    Rear Shock Absorber - Lower Bush SPF2178-16K $9 2B
    Rear Shock Absorber - Upper Bush SPF2755SK $10 4B
    Rear Sway Bar Link Lower Bush SPF0280K $15 4B,2T
    Rear Sway Bar Link Upper Bush SPF0903-4K $9 4B
    Rear Trailing Arm - Lower - Bush All SPF0018K $59 [SOLID AXEL] 4B,4T
    Rear Cross-member To Chassis Mount SPF1447K $115 [Listed under Supra but assume is same as IRS Celica 4B,2T[/b]
    ../delete/ban
    tech moderator
    Junior Member Grease Monkey Joorsh's Avatar
    Default Re: MA61 Noltec and SuperPro Bushes: PN#'s and $$$
    Adjustable strut tops from Noltec for the MA61:
    Part number N44027
    $350 for the pair
    This was accurate as of September 2004, so prices & part numbers may have changed.
    Forum Member Grease Monkey bbaacchhyy's Avatar
    For those that are going to purchase the bushings above, note that SuperPro ones are two pice nolathane only, whereas the Noltec ones are one piece and have a steel outer sleev (in the case of N61666 and N61667) and the front LCA bushings as well.
    For this reason, I prefer Noltec, but it can make them a bugger to install.
    Have some pics at home and will try and host them tomorrow.
    Michael B
    '84 MA61 with 7M-GTE
    Now 5sp, 5 stud,17x8" Ray's, big assed brakes and decent IC
    Better turbo in the wings as well as MAFT !!!!
    Penrith BC
    Quote Originally Posted by bbaacchhyy
    ditto that - but not hard to install if all you do is go "here mr mechanic, please install..."
    ../delete/ban
    tech moderator
    Quote Originally Posted by ed_ma61
    Make sure it is Mr Competent Mechanic. When I took mine to get done, the put the inners in the outer and vice verca. Easily fixed though, but make sure you check it before you leave.
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Also you must not tighten them with the car jacked up above ride height as they will only last a few thousand ks. Do them up loosley, give the car a few bounces and then do them up tightly while at the intended ride height.
    Quote Originally Posted by Enchanter
    CORRECT!!!!! If you ever go into a good suspension workshop, notice that they use several 4-post jacks to work on cars..... i asked a suspension mechanic once why he was working on a car on the ground without it being jacked when there was still a 2-poster not being used, so he explained exactly what you did
    The other trick is to do them up loosely, then drive up some wheel ramps to actually get underneath the car if you dont have much space there.
    Regarding the Rear Sway Bar Mount to chassis bush. Since noone seems to make them here in Australia, Tru-line suspension, just down the road from me were able to help me out in finding something that fits. The bush that we used was from Nolathane part number #42330. This bush is a little short by about 1mm, so you need to grind the edge of the bracket down to accomodate the bush. Apart from that she's a good tight fit. Pictures below to show the modified bracket and bushes.
    Sam
    TAS
    Good work Sam - how much did they set you back?
    EDIT: Ignore my 2nd question - tired.
    TAS
    Note : Credit to me for compiling the original SuperPro list that was posted on the old board and that Ed copied
    Junior Member Domestic Engineer Viper's Avatar
    Just a quick question
    The two above part numbes are the same, yet discription and price differ?? Is this correct? Would seem overly complecated if it was so.
    Daily: '06 Liberty 3.0R specB
    Project Car : '84 MA61: 2JZ-GTE + 6 Speed
    Those bushes cost $21
    Radius Arm (FRONT) N81664
    Thats the proper number.
