Results 46 to 60 of 65
Thread: what engines for RT-142
  1. #46
    Default Re: what engines for RT-142
    Quote Originally Posted by Valkyrie
    Have you thought about a 13B from an RX8?
    The easiest way to save money with this conversion would be to use series 5 turbo box/bellhousing, with a lightweight flywheel and suitable clutch.
    We were seriously looking at this combination for my brothers Sprinter. We're going 4AGZE bottom end and turbo route now though.
    I have been in a new RX8, and thought even in a car ~350(?) kg heavier, it went quiet well. The 13B would be easy to set nicely back in the engine bay as well.
    You would also need, engine mounts g/box crossmember, oil cooler and rebuilt radiator and a thermo fan. Plus all the usual bits and pieces. Most of the aftermarket ECU's will also run the oil metering and variable length manifold 'bits'.
    They are not a bad engine, and I think it would pull the Corona along nicely.
    Just me 2 bob worth.
    Dude a petrol prices, b he doesn't want a convserion, c way to much custom work, d cost.
    If in doubt power out
  2. #47
    have you priced up an RX8 motor????????
    exxy exxy exxy!
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  3. #48
    tasmania
    ...and E: blasphemy can you even get half-cuts or even complete engines yet?
    beer me!
  4. #49
    plus rotaries are poo...forgot that bit
  5. #50
    Junior Member Backyard Mechanic sam-131's Avatar
    20b peripheral port with a triple throat webber = Teh pornstar
    there was a guy a while back on ausrota selling rx-8 engines that came out of the testing/crashed up rx's when they first came out and they were very exxxxxy
  6. #51
    Montrose
    I briefly had the idea of seeing what I could get out of the 22R, all in the name of fun of course, but I just can't convince myself to do it when there's an unloved 1UZ already sitting around the place. It's still something I'd be slightly interested in though - if you do decide to mess with your 22R, I'd be interested to see how far you go with it.
  7. #52
    XR6 turbo engines are pretty awesome, but there's a very good reason they're not used in conversions. You said it yourself, they're exxy - in fact for the money you'd spent on a complete XR6T engine you could easily buy a 1JZ and bolt-ons which will blow its doors off.
    this is true. Still want an XR6T motor tho
  8. #53
    its a 22RE
    2.4L fuel injected as appose to the 2.0L carby you would normally find.
    yes, i own a car, it has four wheels and an engine. and in the end, isn't that what really matters
  9. #54
    Quote Originally Posted by spazworm
    its a 22RE
    have fun finding a 2L carbie motor in a RT-142 , they all have 22re's , the St-141 howevere will have plenty of 2L carbie motors
  10. #55
    your delusional... finding a 2.4L 5speed corona was hard, let alone an avante.
  11. #56
    No i was more poiting at the fact you said its a 2.4L RT142 which is uncommon, all RT142's run the 22re, its the St141 that has the 2L carby motor.
    Sif its hard, I know of about 3 cars almost identical to mine within say a 1km radius of my house,theres also an SR floating round my area.
  12. #57
    come to brissie, there are like 9 rt142 22r3 coronas sitting at salisbury wrecking...and 3 of them are avantes
  13. #58
    sa
    The day I had my GZE dynoed, A VN 5L was also dynoed.
    4AGE pulled 88kw, 240nm
    VN5L pulled 95kw, 260nm.
    Needless to say, my disappointment at the mere 88kw was cured.
    Holden engines are somewhat tragic.
  14. #59
    Quote Originally Posted by myne
    Thats a very sick 5L my mates VN SS was dynoed with only mod being cat back and it had 120-125rwkw. thats about right considering they have 165kw at the flywheel stock. It was an auto as well. I say was cos the car is now a cube
  15. #60
    I'm pretty sure only the HSV's had 165kW back then, the garden variety VN's were a fair bit less.
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 05:25 PM
  2. Mods for 3SFE engines
    By Raceflo in forum Tech and Conversions
    Last Post: 19-01-2018, 11:40 PM
  3. The History Of M engines
    By rob in forum Tech and Conversions
    Last Post: 25-11-2011, 09:56 PM
