1st, ask your engineer. if pump is in boot and you don7t have the right lines, you will likely get fuel smell. why not under the car with suitable protection?
high pressure filter goes after the pump (to protect the injectors). intank pump usually has strainer on it. can use low pressur efilter befor ethe bosch is needed.
doesn7t have to be solid line, but solid is stronger and cheaper...
, and where you want the fuel filter is up to you.
