Results 1 to 3 of 3
Thread: HELP: Fuel system
    Default HELP: Fuel system
    I have just ordered the extrusion for the fuel rail for my ITBed (45mm) 3TG, this is my first EFI conversion so im looking for confirmation on my fuel setup
    I am running:
    -Facet lift pump (one of the bigger ones)
    -WALBRO GSS-341 main pump
    -1.7L (aprox) alloy surge tank
    -Dash 8 fuel rail (regulator bolted directly on the end)
    -Sard fuel regulator
    -Injectors (no idea yet, would like 60HP single spray)
    -For soft lines i want to use speedflow 400 series (im sick of braided lines and cant afford the cotton stuff)
    but not sure on size i was thinking dash 6?
    and for hard lines i was gonna use the standard lines unless anyone has some clever suggestions (bigger better?)
    just for information
    Im running twin injection perfection 45mm throttle bodies
    engine is a 3TG:
    - Bigger ports
    - Nitrided valves,
    - RR4 springs
    - Big cam
    - All new timing chains, tensioners and sliders
    - 87mm bore (once i get bloody pistons!!)
    - 10:1 comp (once i get bloody pistons!!!)
    - lightened fly wheel
    - custom clutch (started its life as a organic sport excedy)
    - bolted onto a T50 (possible P51 in near future)
    ECU will be microtech or autronic (depends on budget at the time)
    Any tips on the fuel system would be very appreciated
    Default Re: HELP: Fuel system
    standard hard lines will be fine for EFI use - my 18rte is using the stock hard lines and most 1ggte installs use the original hard lines (and fwiw, Norbie's 2JGTE used the original 5me hard lines).
    I'd suggest a stock EFI filter and mount so you can adapt the hard-line pipe to EFI-safe flexible hose adn then use factory fittings from teh filter up to the rail. RA65's have one mounted in the engine bay on drivers side - grab the hoses, mount and filter (for the part #) and work out how to fit into your car.
    just remember 'no plain fuel hose after the EFI pump - only EFI-rated hose'. Work out what lengths of different ID's you're after then get it from a hose/fitting shop like pirtek or enzed.
    btw: dont forget to put a low-flow filter upstream of the facet pump - something from a V8 will have good-sized fittings.
    for soft hoses im running 400 series Speedflow hose and fittings (like a fancy rubber hose)
    I will be running a Inline filter just after the EFI pump
  1. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
  2. setting up a fuel system
    By Cam-Rush in forum Tech and Conversions
    Last Post: 17-02-2006, 09:39 AM
  3. 1ggte fuel system mods
    By MOOKIE in forum Tech and Conversions
    Last Post: 02-01-2006, 11:15 PM
  4. Replies: 1
