Page 18 of 43 FirstFirst ... 8161718192028 ... LastLast
Results 256 to 270 of 634
Thread: Megasquirt users thread to discuss all things Squirty
  1. #256
    Genuine Hotty. Conversion King old_mr2's Avatar
    Default Re: Megasquirt users thread to discuss all things Squirty
    Cheers Mate
    PS I have officially cracked the shits with this dizzy and am about to go EDIS!!!!!
  2. #257
    Coming my way
  3. #258
    New Zealand
    Pressume that is from the US? I looked at the stuff on E-bay but freight made it better to get it in NZ, mine came out of a 95 Mondeo 2.0 Zetec.
    Callum
  4. #259
    Jul 2009
    Quote Originally Posted by old_mr2 View Post
    Once you crack the shits with the EDIS limitations, just replace the VR sensor (from the EDIS) at the crank wheel for a Hall Sensor and wire that to the MS. Then you can run wasted spark with spark cut/retard.
  5. #260
    Jul 2009
    Hooray, my 20V is alive!
    Although I had an RPM signal, I noticed I was getting sync errors, and they seem to be very consistant. I had a look at my spare 20V dizzy and noticed that the G wheel is more of a snail shape. I checked my settings and noticed I was running Raising Edge for the Cam Trigger, which by the looks of it was getting false triggered by the snail shape. I flicked it over to Falling Edge, turned the key and she fired up instantly!
    Old, give this a go with yours, it might be doing the same thing. As request, here are my trigger settings.
  6. #261
    Jul 2009
  7. #262
    Jul 2009
  8. #263
    cHEERS kNIGHTROUS, if you could please share one more thing with me. Your wiring info for the dizzy to the MS. Thanks again mate.
    Great work on the 20V!
  9. #264
    Jan 2011
    Quote Originally Posted by knightrous View Post
    Good work man!!
  10. #265
    Jul 2009
    Pretty sure it's just.
    NE -> VR1+
    G2 -> VR2
    G- -> VR- (if not, it will be SG)
    Will confirm when I get home on Friday.
  11. #266
    Thanks again Pal.
  12. #267
    Aug 2011
    vic
    This might help a few of you looking for a timing map. Pulled it from a factory big port ecu 89661-20200.
    4age Bigport timing.zip
  13. #268
    yeah im wondering why you guys jump at the EDIS setup, when you could just chuck a 36-1 trigger wheel and sensor on your crank and run wasted spark that way? I thought the MS could do dual IGbT outputs now?
  14. #269
    New Zealand
    From memory of all the reading I did, EDIS has the coil drivers built in where the MS would need to run outboard coil drivers and I would have had to mod my pre built ECU. For $110NZ for everything I needed it make perfect sense.
    Callum
  15. #270
    Feb 2010
    Jakarta
    Quote Originally Posted by WDE_BDY View Post
    Callum
    .. and perhaps for the other minor advantage: when MS ignition part fails to work, you still get limp-home mode just from the EDIS module alone with timing locked at 10 deg BTDC.
  1. Overboost caused by plumb-back BOV wrong way round! Discuss...
    By Stefan in forum Tech and Conversions
    Last Post: 03-09-2008, 04:39 PM
