Page 16 of 43 FirstFirst ... 6141516171826 ... LastLast
Results 226 to 240 of 634
Thread: Megasquirt users thread to discuss all things Squirty
  1. #226
    Default Re: Megasquirt users thread to discuss all things Squirty
    nice find, and cheap!
  2. #227
    DIY Autotune just released the four channel ignition module, which is based on the same BIP373 coil driver the MS2 and MS3 now use. $89 seems pretty good value.
    QuadSpark Four Channel Ignition Module DIYAutoTune.com
    Depending which COP's I end up finding for the RG, I may need one of these.
  3. #228
    Genuine Hotty. Conversion King old_mr2's Avatar
    Hey Knightrous, Have you had a chance to test your new Hall sensor?
  4. #229
    Jul 2009
    Not yet mate, but might be able to do it tonight, think I'll just stick my spare dizzy in the drill, hold the hall sensor near the NE wheel and see if I get an RPM
  5. #230
    Im keen to hear of your results!
  6. #231
    Jan 2011
    Anyone running a n/a 4age with 288deg cams?? Been doing sme googlein, not fiding much, just woundering if anyone has got a map i coukd use?? Thanks guys, p.s im a complete noob to this....
  7. #232
    Jul 2009
    Quote Originally Posted by domma_aw11 View Post
    I think we can sort most of your hassles out by adjusting that fuel pressure correctly, the MS2 was running super rich because of the high fuel pressure would have been making the injectors flow way more then the MS2 calculates (185cc @ 42.5psi, running 60+ PSI makes a big fuel increase!). Also, to help with the cams, if we rescale the fuel table to start at 50kpa (with those cams, it was idling at 65-75kpa) and scale it to 110kpa it will give a lot more cells to fine tune on the table itself.
  8. #233
    Jan 2011
    Ah okz, i found some ve tables on google for the 16v but then it was i saw it didnt have as big cams and had gsxr itb's so i figured mayb couldnt use it??
  9. #234
    Jul 2009
    Quote Originally Posted by old_mr2 View Post
    I haven't tested it yet, however trying to fit two of these sensors onto the dizzy is going to be a bitch due to the size of the sensors (won't get one close enough to the 1 tooth wheel), but there has been some other developments in a thread on the MSExtra forums.
    Cam Mounted Trigger Wheel
    Looks like with using the cam wheel as a 24-1 trigger (grind 1 tooth off) with a single hall sensor will allow full sequential! This will be piss easy for us to do and will hopefully end this hassle of getting the VR sensors to play nice!
  10. #235
    Jul 2009
    Well, I finally have an RPM signal! A simple case of RTFM and a quick solder in of a resistor and everything works. VR sensor works fine, so no need to setup the hall sensor any more.
    Old, did you read this section in the DIYPNP documentation?
    Cam Adjust: This lets you change the trigger voltage on the VR2 input. R20 increases the threshold trigger voltage, R21 decreases the threshold trigger voltage, and R39 can be adjusted to move it either way. If you already have information on what works for your sensors, solder a fixed resistor to either R21 or R20 as documentation recommends. For example, most Nippondenso ignitions work best with a 51K resistor in the R21 slot and R20 empty.
    If you have R39 installed, remove it and install the 51K in R21. This fixed the problem instantly for me, it might fix it for you
  11. #236
    Thanks for the update knightrous, I will attempt this on the weekend!
  12. #237
    Feb 2010
    anyone got a tunerstudio serial they dont mind be "borrowing" or a crack or something?
  13. #238
    nope, but if you're not running MS3, an alternative is megatunix.
  14. #239
    Mar 2008
    Quote Originally Posted by nuk1ear View Post
    It's not very expensive to buy a license I think you can install it on 3 or so devices too!
    '77 YAMAHA XT500 - Project
    The Drivers' Vault
  15. #240
    Feb 2010
    Yeh much tunerstudio seems much more pretty plus has some cool features like that tune analyser and im planning to run the program as a gauge display too in the car hooking up a couple of extra sensors to the MS3+MS3x inputs.
    Yeah its cheap but im poor lol
  1. Overboost caused by plumb-back BOV wrong way round! Discuss...
    By Stefan in forum Tech and Conversions
    Last Post: 03-09-2008, 03:39 PM
