Results 1 to 8 of 8
Thread: Deleting 1j P/S Idle up valve?
    Nov 2007
    Default Deleting 1j P/S Idle up valve?
    Hi Guys,
    I've got a JZZ30 engine here and it looks like the High pressure line is a part of the idle up valve, different to the jza70 which it's 2 separate parts. the factory jzz30 high pressure line has been cut so I've got a JZA70 hose ready to go on.
    The problem is I cannot leave the current idle up valve on since it has it's own outlet for the factory hose on it. Until I find a JZA70 idle up valve, can I run without one or would the engine totally stall on full lock turns or just the idle decrease a lot?
    Is there any other 1jz, Chaser perhaps that has the same type of idle up valve that JZA70 has?
    Thanks
    Default Re: Deleting 1j P/S Idle up valve?
    My 1JZ used to stall on U turns without a PS idle up valve, wasn't totally un-drivable tho, not like you do a thousand u turns a day.
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    ive got one from a 7M boris you think it will fit? I shall check in the morning for ya
    1992 - JZA70 STOCK - SOLD
    Junior Member Backyard Mechanic zombie's Avatar
    picture of the setup so we can see what the difference is?
    1990 JZA70 R - BLMQZ
    m a n u a l
    Dark green mica
    14.118 @ 101.01 mph (Perth Motorplex, 24/05/06)
    252.1 HP (Hyperdrive, 11/11/06) / 264.2 HP (XSpeed, 24/02/07)
    May 2008
    just had a look at mine my idle up valve is coming out on a angle facing to rear of fire wall very similar look to the MA70 one ive got at home someware. pics would be good boris
    Nov 2007
    I'll get a picture of the one on my JZZ30 engine.
    Carlo if you got a spare 7m one I guess I could try that one if it will work on a 1jz pump.
    Thanks.
    May 2008
    it looks similar to the on my JZ ill check when get home this morning
    May 2010
    Moscow
    I run my 1jz-ge vvti with non-toyota p/s pump (my steering system needs more pressure). So there's no idle up switch to the ECU and no extra air into header when p/s pressure is high. The only thing happening when I steer hard is idle dropping down to some 550 rpm. It stalled just once over period of half a year. So I assume there's no reason to try hard and install some p/s switch.
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
  2. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
  3. 1jz problems with idle and snapped off screw head.
    By tyottsoarer in forum Tech and Conversions
    Last Post: 22-05-2006, 11:39 AM
  4. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
