Results 1 to 7 of 7
Thread: JZA70 and MA70 Specifications
    Default JZA70 and MA70 Specifications
    I found this info and thought that the Turbo Specs and Part numbers may be usefull...
    JZA70 Specifications
    The Toyota Supra JZA70 was released in mid 1990 and was fitted with the first generation of the JZ engine series, the 1JZ-GTE. Rated at 206kw, this pushed the Supra (*TwinTurbo R) to a mid 14 second quarter mile time, 1 second quicker than the MA70 Turbo.
    There were several specs of JZA70, ranging from the packed out luxury model (x) to the sports model (TwinTurbo R). The TwinTurbo R came factory with Recaro seats, steering wheel and shifter knob and matching trim panels, it also came fitted with Bilstein shock absorbers with up rated springs and charcoal 5 spoke alloys.
    Other features of the JZA70 Supra was the replacement of the mechanical clutch LSD with a Torsen unit. The final ratio was also changed to 4.11 compared to the 3.73 of the MA70.
    1JZ-GTE Engine Specifications
    Electronic Injection, Twin CT-12A Turbochargers (parallel), Intercooled
    Valves 24
    Camshafts 2 (DOHC)
    Intake Duration ?
    Intake Camshaft lift ?
    Intake valve diameter 32mm
    Intake Valve timing - Opening ?
    Intake Valve timing - Closing ?
    Exhaust Duration ?
    Exhaust Camshaft lift ?
    Exhaust valve diameter 30mm
    Exhaust Valve timing - Opening ?
    Exhaust Valve timing - Closing ?
    Bore x Stroke (mm) 86 x 71.5
    Capacity (cc) 2491
    Compression Ratio 8.5:1
    Maximum Power 206kw @ 6200rpm
    Maximum Torque 365nm @ 4800rpm
    Redline 7500rpm
    Lubricant & Fluid Capacities
    Oil system 4.8 Litres, 10W-30
    Cooling system 8.3 Litres
    Radiator cap pressure rating 10.7 to 14.9 psi
    Thermostat rating 82 degrees Celsius Part Number 90916-03093 Gasket Part Number 16325-62010
    Spark plugs
    Copper Tip NGK BKR6ES-8N
    Platinum Tip NGK BKR6EP-8 Part Number 90919-01181
    Nippon Denso PK16R8 Part Number 90919-01180
    Other
    Hydraulic unit water pump Part Number 16090-49017
    Hydraulic water pump pulley Part Number 16939-46010
    Non-Hydraulic water pump Part Number 16100-49846
    Non-Hydraulic water pump pulley Part Number 16371-46020
    Timing Belt Part Number 13568-46010 (08/90 - 05/92)* Part Number 13568-49025 (05/92 - 12/92) Part Number 13568-49065 (12/92 - 05/93)
    Serpentine belt Part Number 90916-02306 *Replacement Part Number - 13568-49025
    Manual Transmission Specifications (R154)
    Gear ratios
    Reverse 3.18
    First 3.251
    Second 1.955
    Third 1.310
    Fourth 1.000
    Fifth 0.753
    Gearbox Lubricant Capacity - 3 Litres
    Oil specifications 80W-90 GL4 or 5 Gear Oil
    Diff Specifications
    Final Drive Ratio 4.100
    Differential Code G299
    Drive Pinion - Number of teeth 10
    Ring Gear - Number of teeth 41
    Ring Gear size 200mm
    Driveshaft Diameter 29.60mm
    Differential Lubricant Capacity - 1.3 Litres
    Oil specifications API GL5 Hypoid Non-LSD Gear Oil
    Top Speed km/h @ rpm
    First Gear - 67 @ 7500
    Second - 111 @ 7500
    Third - 166 @ 7500
    Fourth - 218 @ 7500
    Fifth - 289 @ 7500
    Acceleration
    400 metres - 14.5 @ ?mph
    Turbocharger Specifications
    Manufacturer Toyota (Hitachi)
    Type CT-12A (Part Number 17201-46010 (Front), 17208-46010 (Rear))
    Turbine size (Outlet diameter) 42mm
    Turbine size (Inlet diameter) 51.6mm
    Turbine Blade count 8
    Turbine Material Ceramic
    Turbine Housing Outlet (ID) 44.1mm
    Turbine Housing Inlet (ID) 33mm
    Turbine Shaft Diameter 8.5mm
    Turbine housing A/R .45
    Compressor size (Inlet diameter) 35mm
    Compressor size (Outlet diameter) 54mm
    Compressor Blade count 10
    Compressor material Aluminium
    Compressor Housing Inlet (ID) 37.9mm
    Compressor Housing Outlet (ID) 30mm
    Compressor housing A/R .30
    Bearing ID 8.53mm
    Bearing OD 13.55mm
    Bearing Width 9mm
    Bearing material Bronze
    Bearing oiling holes (per bearing) 6
    *Wastegate size (ID) 20mm
    Actuator spring rate 10 psi
    Chassis Specifications (R Spec)
    Driven wheels Rear, Torsen LSD
    Suspension, front Wishbones, Bilstein dampers, coil springs, anti roll bar
    Suspension, rear Wishbones, Bilstein dampers, coil springs, anti roll bar
    Steering Power assisted rack and pinion
    Turns lock to lock 2.8
    Turning circle 10.8mtrs
    Brakes Front 300 x 22mm (21mm min thickness), Vented discs, Single Piston calliper
    Brakes Rear 291 z 18mm (17mm min thickness), Vented discs, Single Piston calliper
    Tyre Size 225/50R16
    Wheel Size 16x7" 5 stud 114.3pcd
    Kerb Mass 1580kg
    Fuel Tank 70Litres
    Body Specifications
    Claimed Cd 0.33
    Wheelbase 2595mm
    Track Front 1485mm
    Track Rear 1480mm
    Length 4620mm
    Width 1745mm
    Height 1300mm
    Interior Dimensions
    Dash to rear seat 1515mm
    Drivers seat to wheel (min/max) 515/750mm
    Drivers seat to pedals (min/max) 350/570mm
    Rear kneeroom (min/max) 45/275mm
    Shoulder width, front 1330mm
    Shoulder width, rear 1280mm
    Front cushion depth 500mm
    Front cushion height (min/max) 250/275mm
    Rear cushion depth 470mm
    Rear cushion height 240mm
    Front door opening length/height 1220/830mm
    Boot Dimensions
    Floor length (seat up) 970mm
    Floor length (seat down) 1500mm
    Floor width (min/max) 750/1300mm
    Floor cover/roof (min/max) 330/640mm
    Opening Depth 1145mm
    Lip to lid 830mm
    Loading height (lip to ground) 900mm
    ([][][]II--LT--II[][][])
    Default Re: JZA70 and MA70 Specifications
    MA70 Specifications
    The Toyota Supra MA70 was released in mid 1986 and was fitted with the 7th generation of the M engine series, the 7M-GTE. Rated at 173kw of power and 344nm of torque, this pushed the Supra to a mid 15 second quarter mile time.
    7M-GTE Engine Specifications
    Electronic Injection (AFM), CT-26 Turbocharger, Intercooled
    Valves 24
    Camshafts 2 (DOHC)
    Intake Duration 200
    Intake Camshaft lift 7.44mm
    Intake valve diameter ?
    Intake Valve timing - Opening 6° BTDC
    Intake Valve timing - Closing 50° ABDC
    Exhaust Duration 201
    Exhaust Camshaft lift 7.44mm
    Exhaust valve diameter ?
    Exhaust Valve timing - Opening 53° BBDC
    Exhaust Valve timing - Closing 3° ATDC
    Bore x Stroke (mm) 83 x 91
    Capacity (cc) 2954
    Compression Ratio 8.4:1
    Maximum Power 173kw @ 5600rpm*
    Maximum Torque 344nm @ 3200rpm
    Redline 6500rpm**
    *Late model 7M-GTE's had a slight power increase to 176kw, torque remained unchanged.
    **Late model 7M-GTE's contained a fully counter balanced crankshaft which reduced the redline to 6250rpm
    7M-GTE Engine Specifications (GT Turbo A)
    Electronic Injection (MAP), CT-26 Turbocharger, Intercooled
    Valves 24
    Camshafts 2 (DOHC)
    Intake Duration 210
    Intake Valve timing - Opening ?° BTDC
    Intake Valve timing - Closing ?° ABDC
    Exhaust Duration 211
    Exhaust Valve timing - Opening ?° BBDC
    Exhaust Valve timing - Closing ?° ATDC
    Capacity (cc) 2954
    Maximum Power 204kw @ 5600rpm
    Maximum Torque 354nm @ 4400rpm
    Redline 6500rpm
    7M-GE Engine Specifications
    Multipoint Fuel Injection (AFM), Normally Aspirated
    Valves 24
    Camshafts 2 (DOHC)
    Intake Duration ?
    Intake Camshaft lift @ 50 Thou 7.44mm
    Intake Valve timing - Closing 40° ABDC
    Exhaust Duration ?
    Exhaust Camshaft lift @ 50 Thou 7.44mm
    Capacity (cc) 2954
    Compression Ratio ?:1
    Maximum Power 149kw @ 6000rpm (200HP)
    Maximum Torque 255nm @ 3600rpm (188ft/lb)
    Redline 6500rpm
    Oil system 5 Litres, 10W-30
    Thermostat rating 88 degrees Celsius Part Number 90916-03083 Gasket Part Number 16341-35010
    Spark plugs
    Copper Tip NGK BPR6ES
    Platinum Tip NGK BPR6EP Part Number 90919-01146
    Nippon Denso PQ20R Part Number 90919-01145
    5 Speed Manual Transmission Specifications (7M-GTE)
    Gearbox model R154 Km/hr per 1000rpm
    Reverse 3.18
    First 3.251 9.6
    Second 1.955 16
    Third 1.310 24
    Fourth 1.000 31.4
    Fifth 0.753 41.7
    Oil specifications SAE 80W-90 GL4 or 5 Gear Oil
    Diff Specifications (7M-GTE Manual)
    Final Drive Ratio 3.727
    Differential Code G305
    Drive Pinion - Number of teeth 11
    5 Speed Manual Transmission Specifications (7M-GE)
    Gearbox model W58 Km/hr per 1000rpm
    Reverse 3,768
    First 3.285
    Second 1.894
    Third 1.275
    Fourth 1.000
    Fifth 0.783
    Gearbox Lubricant Capacity - 2.6 Litres
    Oil specifications SAE 75W-90 or 80W-90 GL4 or 5 Gear Oil
    Diff Specifications (7M-GE Manual)
    Final Drive Ratio 4.3
    Differential Code
    Ring Gear - Number of teeth 43
    4 Speed Automatic Transmission Specifications (7M-GTE)
    Gearbox model A340E Km/hr per 1000rpm
    Reverse 2.393
    First 2.804
    Second 1.531
    Third 1.000
    Fourth 0.705
    Gearbox Lubricant Capacity - 7.2 Litres
    Oil specifications ATF Type II Dexron
    Diff Specifications (7M-GTE Automatic)
    Final Drive Ratio 3.7272
    4 Speed Automatic Transmission Specifications (7M-GE)
    Reverse 2.393
    First 2.804
    Second 1.531
    Third 1.000
    Fourth 0.705
    Diff Specifications (7M-GE Automatic)
    Differential Code
    Speedo Corrections
    Speedo km/h - True km/h
    60 - 58
    80 - 78
    100 - 97
    120 - 117
    First Gear - 62 @ 6500
    Second - 104 @ 6500
    Third - 156 @ 6500
    Fourth - 204 @ 6500
    Fifth - 275 @ 6500
    Acceleration
    Standing start to... Time (Seconds)
    60km - 3.5
    80km - 5.5
    100km - 8.1
    120km - 11
    400 metres - 15.5 @ 92mph ; GT Turbo A 14.4 @ 98mph
    Rolling start (7M-GTE) 3rd Gear, 4th Gear, 5th Gear
    40-70km - 4.8, 5.6, 9.8
    60-90km - 4.2, 5.3, 8.6
    80-110km - 4.0, 5.2, 7.6
    100-130km - 4.6, 5.4, 8.0
    Type CT-26 (Part Number 17201-42020)
    Turbine size (Outlet diameter) 52mm
    Turbine size (Inlet diameter) 68mm
    Turbine Blade count 11
    Turbine Material Steel
    Turbine Housing Outlet (ID) 60.6mm
    Turbine Housing Inlet (ID) 60mm
    Turbine Shaft Diameter 10mm
    Turbine housing A/R ?
    Compressor size (Inlet diameter) 46mm
    Compressor size (Outlet diameter) 65mm
    Compressor Housing Inlet (ID) 70mm
    Compressor Housing Outlet (ID) 61.5mm
    Compressor housing A/R ?
    Bearing ID 10.05mm
    Bearing OD 16.9mm
    Bearing Width 9mm
    *Wastegate size (ID) 25.8mm
    Maximum wastegate size (ID) 28mm
    Actuator spring rate 6.8 psi
    Weight Distribution
    Brakes Front 302 x 22mm (21mm min thickness), Vented discs, Single Piston calliper
    Brakes Rear 291 x 18mm (17mm min thickness), Vented discs, Single Piston calliper
    Tyre Size 225/50R16
    Kerb Mass 1600kg
    Fuel Tank 70Litres
    Body Specifications
    Claimed Cd - Without wing 0.33
    Claimed Cd - With wing
    Wheelbase 2595mm
    Track Front 1485mm
    Track Rear 1480mm
    Length 4620mm
    Width 1745mm
    Height 1300mm
    Interior Dimensions
    Boot Dimensions
    Lip to lid 830mm
    ...courtesy of http://turbosupras.com/
    JZA70|R / 12.45 @ 111 mph.
    Quote Originally Posted by JZA70 R
    That's the one...
    Jun 2009
    I know this is an old thread but have it book marked and I've still used it in many relatively recently times including today
    I came across this post on the US supra forums quite some time ago and found the cam specs for the 1JZ if you wanted to do a small update
    http://www.supraforums.com/forum/sho...s-into-1jz-gte
    Intake / Exhuast
    1JZ-GTE
    Lift 7.69 / 7.95
    Duration (adv) 224 / 228
    Duration @ .050" 189.1 / 194.1
    lobe centre
    you're cool if your car goes stututu
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    Does anyone know the 0-100 times of a JZA70? and some documention to back it up? Going to start prepping the car for targa events and need to know what level of modification I can go to.
    Subscribed !
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  1. Hilux Diff Centre - JZA70 Torsen Installation
    By Pure_In_Sanity in forum Tech and Conversions
    Last Post: 05-12-2011, 09:52 AM
