Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: 18rgeu turbo pcv valve setup
    Aug 2008
    Default 18rgeu turbo pcv valve setup
    Default Re: 18rgeu turbo pcv valve setup
    it sounds like your plumbing it into the breather..
    catch can and just plumb the pcv and the breather into it and then put a drain in the sump?
    Aug 2008
    show us a photo of what your doing man
    the pcv goes from pressure built up in the crank case (the lower half of the engine) there is a one way plate from the block which needs to be fed to the intake to pass emissions.. pre-turbo!
    there is also a breather from the top of the motor from the rocker cover.. this can go to a catch can or also pre turbo
    the big problem is spraying oil everywhere.. which is where im thinking your plumbing it in after the turbo essentially your pressurizing the crankcase or the rocker cover
    this is my old rg
    you can see the rocker cover being vented to the intake.. this would be no different to plumbing it in BEFORE the turbo
    i dont think i have a pic of crank case (i really cant remember it actually..)
    Aug 2008
    Aug 2008
    if you just put it before the turbo it wont matter
    im hunting through pics now.. from memory i cant remember a crankcase vent?? anyone?? but then again my was non EFI
    there should be diagrams on here also.. did you check the 18r-gte thread? it is epic long tho
    EDIT: that is a fucking good looking motor
    Aug 2008
    yeah i think youre right with vac on the blow by.. makes sense with that pic yeah
    i could be completely wrong and the engine design is such that it vents via that one breather in the top.. in which case that diagram you posted would make sense..
    PM a link to this thread to justenGT8.. he is an 18rgte guru and will be able to tell you
    sorry if i misled you at all
    EDIT river just built one of these too!
    Aug 2008
    thats the way to go mate.. come back here in a day or twos time and the answer will be here
    all the best with the greenslip d00d
    also for all he's concern as long as you are recirculating those gasses it shouldnt matter..
    good luck!
    Aug 2008
    Jan 2008
    queensland
    dont shoot me down if i am wrong but would you not plumb both the breather and the pcv to the catch can as the plenum is pressurised and the pcv requires vacuum which it will get from the turbo and still allow the oil caught in the catch can to drain to the sump
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    yeah thats what i thought and going from rivers engine thats all you need to do
    see below
  1. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 12:06 PM
  2. 18rgeu + TURBO
    By kristian in forum Tech and Conversions
    Last Post: 07-09-2007, 11:01 PM
  3. Turbos 101
    Last Post: 24-01-2007, 08:23 PM
