Results 46 to 60 of 68
Thread: How does it work: 4age oil pump?
  1. #46
    teq Grease Monkey
    California
    Default Re: How does it work: 4age oil pump?
    Yeah, I would think the bearings would go first. Just pondering possibilities.
    Andrew
  2. #47
    May 2010
    TAS
    Harmonics from the crank? It is driven directly off the snout...
  3. #48
    Okay, time for a bit of thread revival.
    Did you guys draw any conclusions on these Toga pumps? Are the gears really 4130 steel? I noticed they stopped selling them for a while, now they are floating around various online stores. I'm looking at replacing my stock oil pump soon and am trying to decide what the best possible oil pump is to get for my turbo setup.
    Also, just as an aside, there are a few OEM Aisin pump available online, some on ebay and their price is much more competitive. So minus the "would you risk it?" question, is there a chance that other aftermarket/knock off pumps are made with worse quality alloys?
  4. #49
    I have since been told that the reason oil pump gears break is due to a pressure overload due to the undersize outlet. It can be modified or alternatively a 7afe pump can be put in which is based on the TRD design. I am going to look into it myself.
  5. #50
    Feb 2007
    Timaru
    Have had a bit to do with ford oil pumps too lately on some projects,
    XR6T and some newer ford V8 race engine's which are all prone to oil pump failure.
    They are saying it has nothing to do with oil pressure, cavitation etc etc,
    all to do with engine harmonics and the rev limiter which causes massive speed oscillations in the crank.
    Apparantly it applies to all engines where the pump gear is physically around the crankshaft.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  6. #51
    Well there is a whole new level of vibration proofing that needs to be done nearing 10,000 rpm for most engine blocks, being a direct drive pump this would make sense.
    In my case I'm not so worried about cracking of the pump gears as I am about getting a pump that has suitable flow with a turbo. While I'm not opposed to the OEM pump, I'm wondering if there's a better pump available in this respect.
  7. #52
    Feb 2007
    Timaru
    Quote Originally Posted by Talasas View Post
    In my case I'm not so worried about cracking of the pump gears as I am about getting a pump that has suitable flow with a turbo. .
    How much extra flow do you need?
    - KE70 Corolla Dx -
  8. #53
    Well if the stock pump is suitable, none. Otherwise whatever pressure and/or flow changes arise from having an oil cooler and a turbo.
  9. #54
    Chiba
    You can always 'port' the stock pump. Grab your Dremel and round off all the sharp edges the oil has to flow around.
  10. #55
    S.A
    are these pumps the real deal? 4130 or just wana be's?
    Worth there money or shouyld i just shell out for the toda one?
  11. #56
    Chiba
    I stuck with the stock item, ported it and shimmed the relief valve for a bit more pressure at high RPM.
    I've seen comparisons between OEM and Toga, and they look identical.
  12. #57
    Jul 2008
    Auckland
    Id also stick with the stock or get the Toda gears.
    Now 9AGTE 410kw atw
  13. #58
    oregon
    Quote Originally Posted by Sam_Q View Post
    talk..... Is porting the outlet enough? Does it require an overbore?
  14. #59
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Regarding TOGA pumps I am in the opinion that they are not high volume nor 4130 gears,
    they might be shimmed for extra pressure but as we all know volume and pressure are
    not the same. Lets just say low volume aftermarket billet oil pump gears cost a lot.
  15. #60
    Low rep Grease Monkey
    Apr 2010
    bkk
    you learn something new every day.
  1. 4age oil pump mods
    Last Post: 24-08-2014, 03:50 PM
  2. Dry-sump construction
    By Billzilla in forum Tech and Conversions
    Last Post: 19-10-2007, 01:51 PM
  3. 4age fuel pump for 4agze
    By dug in forum Tech and Conversions
    Last Post: 30-06-2006, 07:10 AM
  4. Replies: 1
