Yes, the oil pump is driven directly by the crank (not through a belt or gear or anything)
Hi I have a TOGA high volume oil pump and want to install it. how does this connect to the crank shaft and how does it work? Does a part of the crank goes in the oil pump gap or not?
Here is an illustration of the Toga oil pump.
b.t.w. the original oil pump is the same size as this one.
Thank in advance for the help.![]()
The standard 4age oil pump is pretty damn good anyway.
the pump is driven by the flat on the nose of the crankshaft. if you see those two parts you were pointing too - that sits on the flat piece. as the crank rotates so does the oil pump thus rotating the two meshed gears inside and pumping oil as a result.
There is only 1 way, its outlined in the FSM.
Take the back plate off, take a picture of the gear and measure the gear 'rotor' thickness. Post it up here. That would tell us what it's real value is compared to OEM. I did a lot of 'research' on the factory pumps to figure out what's the better one(s) to use.
Looking at the pic of yours, it appears you have the old style pump which should have a square cut gear. This is the one that's prone to failure and the reason why TRD made a stronger gear for it. That's why I would like to see a measurement of the thickness of the rotor gear and whats below the cover.
Andrew
btw if the pump is dry, make sure you pack it with petroleum jelly or some greese, and lightly smear the gear back and front so it can turn easily on start up..
otherwise when you first crack her up you WILL have no oil pressure, as the air in the pump wont let the pump do its job, the jelly or greese helps the pump with initial vacuum to suck oil from the pick up tube..
its not like you have to pack the crap out of it.. just try to half fill the gaps and wipe away excess and put backing plate back on.. simple
you need an impact screwdriver to undo the screws mate.
