Results 1 to 15 of 18
Thread: Spigot Bush from hell removal : 4AGE
    Hoppers Crossing
    Default Spigot Bush from hell removal : 4AGE
    OK, so we all are used to packing grease in behind the bush, banging a bolt in and the spigot bush popping out - EASY right!
    .....cept when the grease pushes thru the bearing and its wedged in there...
    So off to Bunnings to get 1 x 12mmx60mm Dynabolt looks about like this
    Remove the nut, slide the thick end into the center of ye fuxoid spigot bush, then, gently tap the metal shroud onto it as well. Put a washer on the end of the bolt and screw the nut on nice and tight ; resulting in this
    a pair of multigrips for some leverage will look like this ; i managed to get a crowbar in behind it and with some swift pries it came out
    result
    Hope this helps someone in their travels, I searched high and low and found the usual grease pack variety PLUS the other way of doing this is with a slide hammer also......then a brief encounter on r31skylineclub (thanks to beersandwich) netted the above.
    1/2 a day to remove a spigot bush. Far out.
    Default Re: Spigot Bush from hell removal : 4AGE
    dynabolt is a good idea!
    I grabbed someone elses idea of using wet paper/cardboard instead of grease, cos the grease only works half the time.
    May 2010
    TAS
    Top tip Grega!
    Aug 2009
    chisel also works, takes 10 minutes to smash the little f**ker apart..
    Apr 2007
    wilcannia NSW
    Quote Originally Posted by oldcorollas View Post
    wet paper is the shiz. i haven't been beaten yet. ( touch wood. ) it doesn't squeeze through an unsealed bearing like grease will and it leaves the area clean after you prise it out.
    Junior Member Grease Monkey tojo's Avatar
    Aug 2009
    Norway
    Good idea using the expansion bolt. Would sort out the stubborn ones
    edit : could easily combine with a sliding hammer
    KE17 TE38 KE35 KP61 KZN130
    I picked up this same tip as Oldcorollas here.
    Worked heaps better than the grease method, and faaaaaaar less messy.
    You do need to ram a fair bit of paper in there, but it works quite well once you've packed enough in.
    I used newspaper cos it was the easiest to work with.
    the dynabolt way looks like it would work better if there is rust and crap preventing the bearing coming out.. allowing you to put more force on it (and maybe rip the middle out )
    paper method is not great if the sides of the bearing have fallen to bits..
    Aug 2009
    I'm planning a 4afe to 4agze engine conversion - stripping gze down at the moment for rebuild.
    Is this spigot removal something I'll have to do?
    Hoppers Crossing
    no i don't believe so ; the spigot bush IIRC only exists for the RWD models the FWD don't have them although happy to stand corrected.
    May 2010
    TAS
    I second that Grega , FWD has no spigot bush.
    Aug 2009
    Thanks guys
    Jul 2010
    Good one Grega !!!
    Did you borrow my Stanly knife ??? Ive got six of them lol
    Ae90 Hatch 4AGTE Small port http://www.toymods.org.au/forums/showthread.php?t=64566
    Same car More info http://www.toymods.org.au/forums/showthread.php?t=63892
    LAUGH NOW CRY LATER ! Cars and Girls will do that to you !!!
    Hoppers Crossing
    hehehe. nah thats the special GST - you've heard of WST and SST - Gregs Special Tool - modified with sticky tape to stop the broken ass blade retracting
    If your stuck in the field grass works also
    Last Post: 17-06-2008, 09:53 PM
  2. Spigot bearing installation Problems?!
    By Aust162 in forum Tech and Conversions
    Last Post: 28-06-2007, 06:38 PM
  3. 4AGE spigot bearing help!
    By Starfire in forum Tech and Conversions
    Last Post: 18-12-2006, 09:10 PM
  4. Spigot bush mobile phone pidgeon...?
    By Rallystanza in forum Tech and Conversions
    Last Post: 03-02-2006, 01:56 PM
