Ok lets try this ???
New oil return is angled down !!!!!! And is 17mm ID if this doesn't work than it has to be stuffed !!!!!!!!!
Will be welding it in tomorrow !!!!
The return is belled at the end (inside the sump) to 19.5mm ID Just in case![]()
man i wish my ae92 dash looked that good when i put the 100kw motor in it
Ae90 Hatch 4AGTE Small port http://www.toymods.org.au/forums/showthread.php?t=64566
Same car More info http://www.toymods.org.au/forums/showthread.php?t=63892
LAUGH NOW CRY LATER ! Cars and Girls will do that to you !!!
Much better!
sweet, let us know how you go?
facepalm worthy?
you are going to silver-solder a copper pipe in the sump?
Same design just with a mad soldier job!!!!!!
ummm..... I know people braze these things in sometimes. (ie. a certain gay garage in town here uses a spike to punch a hole in sumps and then brazes in fittings for oil drains). I have never liked the idea, but I cannot comment on its effective or defective ness as I have never looked into it further or done it personally.
I am sure people here have though? FWIW I still dont like the idea. But meh, go for it if you like?![]()
Man i love your work and i give you 100% !!!!! you have helped me so-much !!!!! but this is what you haven't tried and ill give it one for the team !!!!
This will work and i am going to prove it
Ps will be closely checking if it leaks so don't try this at home people !!!!
they'd be punching a hole in the sump instead of drilling as it wouldn't create swarf to run around inside the block - note i take it they're doing this on sumps already on cars. not ideal but yeah you get that...
nothing wrong with brazing - is very effective.
Grega - yeah on sumps already on cars. and cool! I had doubts about solder, but if it works then it works!
Adam - Good luck buddy! I am keen to see the result!![]()
Here we have it
Before i clean it up so there's no cheating
Yes its solid to the lip to just for strength![]()
