Page 2 of 24 FirstFirst 123412 ... LastLast
Results 16 to 30 of 353
Thread: Micotech 4AGTE
    Jul 2010
    Question Re: Micotech 4AGTE
    Hey all .. had some time to sit down and type LOL ( I'm pretty slow at it )
    Ok here we go first ....
    im only looking at running about 5 to 10 psi ( to start with )
    every thing is stock !!!! bar pod and 2" cat back exhaust....
    So far i've got in parts ....
    intercooler and piping $ 340
    flebay mani $200
    t28 bb trubo free
    microtech lt8 v1 $360
    now the main problem is that i downloaded a manual for the micro-leb and the wire colors are different so im abit lost ??? i'm pretty good at the mec side but need some help to wire it up .....
    the car was a factory se 1.4lt carb but i wasn't happy with it so i brought a shit sx seca for $600 and stripped it and Put in the small port ( much more gooda)
    all-so done the cluster and made my short shifter ,4 wheel disc brake setup and lowered it 2' all way round kings and Monroe GT Sports.
    all the work has been done buy ME and Me only so i intend on doing the full turbo setup to....
    this is my street legal go-cart lol
    i have added some more pics and wiring diagram that i have ....
    thank all that have help so-far but there is still so-far to go
    Ps how do i get the pics in here insed of attaching them ?????
    Jul 2010
    Default Re: Micotech 4AGTE
    more pics form the Go-Cart
    Dose anyone no if i can use the hand controller cable for my laptop or do i have to buy the laptop plug ?????
    Jul 2010
    Thanks boona ... but y would i want to replace with a gze ???? the only diff is the pistons lol
    and when i brake it that is the first thing im buying ....
    Ps you have done some nice work ... just need to fire her up and get it on the dyno and show her off ... nice job
    Can't touch this Backyard Mechanic boona's Avatar
    Aug 2008
    whats different about the wire colours? I have the MTX-8 wiring diagrams, but I bet that if yout MT wiring diagram is wrong, the mine is utterly useless to you...
    Maybe the colours are different, but function can be inferred from their position on the plug?
    1987 AW11 MR2
    AE92 4AGZE, S15 T28, Adaptronic E420C build in progress
    http://www.toymods.net/forums/showthread.php?t=53945
    Professional: www.danswell.org
    Jul 2010
    Quote Originally Posted by boona View Post
    Thats what i don't know ?? if someone has got a LT8 diagram or has some info on the difference it would help me heaps
    see untitled.jpg and 201.jpg and there is a big difference ????
    Try these, I think you have a loom someone has played with. This is what I would do.
    16-way plug
    BATT +ve ----> red wire
    IGN +12V ----> pink wire (Also goes to fuel pump relay coil)
    GND ----> both brown wires
    AIR TEMP ----> black wire next to brown wires
    OXYGEN SENSOR ----> black wire with red stripe (not necessary, only for datalogging, etc)
    INJ #1 -VE ----> yellow wire
    INJ #2 -VE ----> orange wire
    INJ #3 -VE ----> yellow wire with black stripe
    INJ #4 -VE ----> orange wire with black stripe
    TPS SIG ----> grey wire
    TPS +5V ----> blue wire
    WATER TEMP ----> purple wire
    FUEL PUMP RLY ----> green wire (other coil terminal of fuel pump relay)
    AUX OUTPUT ----> white wire (possibly has a stripe, but should be only white wire there)
    AUX INPUT ----> blue wire with red stripe
    6-way plug
    IGN OUTPUT ----> grey wire with blue stripe (triggers ignitor, you keep your dizzy and leads)
    4-way plug
    GND ----> blue wire (possibly turns to black wire at other end and also grounds the cables screen)
    CRANK INPUT 1 ----> green wire
    CRANK INPUT 2 ----> red wire
    just remember to ground the other side of your water temp sensor to one of the brown ground wires, along with the TPS ground and the air temp sensor if you decide to use one (not required to run)
    the pink and green fuel pump relay wires goto terminals 85 and 86 on the fuel pump relay too, in case you weren't sure.
    refer here for TPS wiring info specific to 4AGE throttle position sensors
    http://www.microtechefi.com/pdf/TPSDiag.pdf
    and here for how to wire the 3 wires to the crank angle sensor in the dizzy
    http://www.microtechefi.com/pdf/LT84CYLTOYOTAign.pdf
    hope you can interpret all that mate!
    let me know if you have any more questions, I have done several of these installs before and am more than willing to help you out!
    Aug 2008
    ^^^^ awesome information.
    1987 AW11 MR2
    Jul 2010
    Quote Originally Posted by RT40Corona4AGTE View Post
    Mate you are a guru and Thank you so much ive been sitting here all day trying to put the to together and gave up ... you'll have to come to sydeny town (shit ney town ) some time and take the go-cart for a spin ,,,, thanks heaps
    no problems mate, feel free to PM me if you get stuck! Best of luck!
    Jul 2010
    16-way plug
    6-way plug
    4-way plug
    Just one more question .... with injectors the standard harness has 1 and 2 on the same wire and 3 and 4 the same do i need to run new wires to them or is there a trick ???
  1. 4agte clutch setups
    Last Post: 26-06-2008, 11:32 AM
  2. nitrous & 4agte
    By caibs in forum Tech and Conversions
    Last Post: 16-08-2007, 10:46 AM
  3. 4agte Info
    Last Post: 16-03-2007, 08:15 PM
