more pics form the Go-Cart
Dose anyone no if i can use the hand controller cable for my laptop or do i have to buy the laptop plug ?????
Hey all .. had some time to sit down and type LOL ( I'm pretty slow at it )
Ok here we go first ....
im only looking at running about 5 to 10 psi ( to start with )
every thing is stock !!!! bar pod and 2" cat back exhaust....
So far i've got in parts ....
intercooler and piping $ 340
flebay mani $200
t28 bb trubo free
microtech lt8 v1 $360
now the main problem is that i downloaded a manual for the micro-leb and the wire colors are different so im abit lost ??? i'm pretty good at the mec side but need some help to wire it up .....
the car was a factory se 1.4lt carb but i wasn't happy with it so i brought a shit sx seca for $600 and stripped it and Put in the small port ( much more gooda)
all-so done the cluster and made my short shifter ,4 wheel disc brake setup and lowered it 2' all way round kings and Monroe GT Sports.
all the work has been done buy ME and Me only so i intend on doing the full turbo setup to....
this is my street legal go-cart lol
i have added some more pics and wiring diagram that i have ....
thank all that have help so-far but there is still so-far to go![]()
Ps how do i get the pics in here insed of attaching them ?????![]()
Thanks boona ... but y would i want to replace with a gze ???? the only diff is the pistons lol
and when i brake it that is the first thing im buying ....
Ps you have done some nice work ... just need to fire her up and get it on the dyno and show her off ... nice job
whats different about the wire colours? I have the MTX-8 wiring diagrams, but I bet that if yout MT wiring diagram is wrong, the mine is utterly useless to you...
Maybe the colours are different, but function can be inferred from their position on the plug?
1987 AW11 MR2
AE92 4AGZE, S15 T28, Adaptronic E420C build in progress
http://www.toymods.net/forums/showthread.php?t=53945
Professional: www.danswell.org
Try these, I think you have a loom someone has played with. This is what I would do.
16-way plug
BATT +ve ----> red wire
IGN +12V ----> pink wire (Also goes to fuel pump relay coil)
GND ----> both brown wires
AIR TEMP ----> black wire next to brown wires
OXYGEN SENSOR ----> black wire with red stripe (not necessary, only for datalogging, etc)
INJ #1 -VE ----> yellow wire
INJ #2 -VE ----> orange wire
INJ #3 -VE ----> yellow wire with black stripe
INJ #4 -VE ----> orange wire with black stripe
TPS SIG ----> grey wire
TPS +5V ----> blue wire
WATER TEMP ----> purple wire
FUEL PUMP RLY ----> green wire (other coil terminal of fuel pump relay)
AUX OUTPUT ----> white wire (possibly has a stripe, but should be only white wire there)
AUX INPUT ----> blue wire with red stripe
6-way plug
IGN OUTPUT ----> grey wire with blue stripe (triggers ignitor, you keep your dizzy and leads)
4-way plug
GND ----> blue wire (possibly turns to black wire at other end and also grounds the cables screen)
CRANK INPUT 1 ----> green wire
CRANK INPUT 2 ----> red wire
just remember to ground the other side of your water temp sensor to one of the brown ground wires, along with the TPS ground and the air temp sensor if you decide to use one (not required to run)
the pink and green fuel pump relay wires goto terminals 85 and 86 on the fuel pump relay too, in case you weren't sure.
refer here for TPS wiring info specific to 4AGE throttle position sensors
http://www.microtechefi.com/pdf/TPSDiag.pdf
and here for how to wire the 3 wires to the crank angle sensor in the dizzy
http://www.microtechefi.com/pdf/LT84CYLTOYOTAign.pdf
hope you can interpret all that mate!![]()
let me know if you have any more questions, I have done several of these installs before and am more than willing to help you out!
^^^^ awesome information.
1987 AW11 MR2
no problems mate, feel free to PM me if you get stuck! Best of luck!![]()
