Vr vs uses parralell cond but sepintine evaps. Vt and many comp now days are variable displacement and run just like the old epr valves, if you keep the suction pressure constant no need for a thermostat. Normally when the valve fails you get no suction pressure at all, sometimes they don't destroke the comps ant they just run flat out and will pull down the suction beyond set point and freeze. Varying pump out put is better on fuel/environment and also better on the pump with far less shock load as they aren't stopping and starting all the time.
