Turbo 4K setup have been done. But for the cost/power ratio i don't think its worth it.
you wont be running side draught carbies on a turbo setup unless you have lots of money to spend, Blow through can be done with a set of webbers etc, but tunning and setup takes alot of work.
Id go a small turbo, suck through setup with a 1.75 SU carb, The carby is directly fitted to the inlet of the turbo, the turbo will draw air/fuel through the carb into the turbo and compress it and feed it to the engine, easy way to make a little extra power for a minium cost, You will need to find a turbo witha carbon seal as these can run fuel through them, You cannot run fuel through all turbos. any where from $300-$500
Then there is blow through with a carb, the turbo compresses the air and pushes it through the carb on the manifold to feed the motor, cost more as youll need to mod the carb for boost,higher fuel pressure as youll need to keep fuel pressure ubove the boost level, so 7 psi boost youll need 12+ psi fuel pressure (standard is around 4-6 psi), youll be able to run a intercooler etc with this setup.
$400-$600+
Get a 4K-E/7K-E inlet manifold, Aftermarket ECU etc. Fuel injection is the way to go, The torque you make with this will make a huge diffrence without the turbo. Add the turbo and it will make ok power, But it will cost alot more $700-$1000+
it wont last long either way you do it, problem is the excels will still beat you, so youll up the boost and break the engine.
find a cheap twin cam engine conversion even a 2t-geu or something.
from the rollaclub
