Results 16 to 30 of 46
Thread: Tacho tech
    Default Re: Tacho tech
    i have had some autometer tachos needing signal boosters
    so i go afew especially for these
    most toyota ecus dont have tacho signal outputs unless they are diesels
    most toyotas have ig- on ignitor
    i have never had any tacho probs with mr2s
    except for a microtech with m and w ignitor i had to use an autronic tacho booster
    these arernt cheap thou i do have a dmamaged one in my car so ill pull it apart and see how they made it
    Who wants to make me one of those signal converters for me? Ill give ya $20 plus parts and postage.
    20 bucks
    i dont get out of bed for less than 100 bucks ehehehe
    I would like to add that when I was playing with the tacho on the 1JZ, it had a +12V square wave output, not +5V...
    It is 12V indeed, as is the 2JZ one (and probably a bunch of others). Each pulse is also approximately 1mS in duration.
    Not sure what the IS200 has, but it's a signal generated by the engine ECU as it has individual coils with integrated ignitors.
    You can make the example given by Hen yourself More sophisticated units (better signal conditioning and output pulse shaping) are time consuming to assemble (I wouldn't make one for less than $100 either ).
    Quote Originally Posted by timbosaurus
    Something I cant understand about the "add ur own potentiometer" article (although i didn't have a good read) is how putting one across the incoming square wave signal can adjust the reading? A pot does sweet FA to the frequency of a signal... only affecting the voltage and maybe the speed of the edges.
    Quote Originally Posted by hen
    So the tach doesn't actually count the frequency, instead it converts it to a DC equivalent. So the added pot just scales this DC equivalent.
    Sounds weird... i thought he said it connects between the two inputs on the tach. would seem odd to have an analog signal into the tach in these digital days
    The older tachos (like the ones in the images, IE AE86, AE82, G/MA70, etc) have one winding on the coil of the needle which the article suggests putting the pot across - not the input to the circuit. This coil responds to the effective or resultant average voltage applied to it. Applying a short spike of a certain voltage will result in a low average voltage. A longer spike will give a higher average voltage. The driver circuit takes the frequency of the incoming signal and applies it to the coil of the needle, while also varying the width of the pulses. So two things are being changed - the frequency of the pulses, and the width of each pulse - to affect the needle position.
    If you add a pot or other resistance in parallel with the coil, the resulting voltage will be lower as the resistor will draw some of the power available from the driving circuit (in theory - not measured or tried).
    Newer tachos (and I think all electronic speedos) use a 4 winding coil with 4 inputs - sine +, sine -, cosine +, cosine -. The benefit of these is a high degree of linearity along a wide arc - full 360 degree rotation is possible. The pot mod will not work with any degree of accuracy on one of these.
    While the driver chip for such a meter might be operating digitally, the required signals on the 4 inputs are analogue. (If you want more info on how these work search for "differential air core meter driver" in google and read the background theory of the application notes for the various chips).
    Mos.
    i sell boosters startin from 40 bucks to 150 for autronic ones
    well done. very interesting read
    Quote Originally Posted by sideshow
    you have PM
    Act
    Just a quick opne here
    I just bought a speco tacho and it will read upto about 700rpm however will not rev past.
    with the inbuilt shift light set low the shift light goes off but the needle won't go above the 700rpm mark
    do I need a booster
    running the signal from the diagnositcs box,
    engine is 7MGTE
    maybe its trial and error
    Act
    nah a calibrated tap solved the problem
    May 2006
    Excellent guide Hen!
    So has anyone tried modifying their AE86 cluster following the guide?
    Where abouts is the tacho drive located? Behind the cluster?
    i use my tacho boosters when fititng 20v or gze into an ae86 they work all the time n ae86 tachos
    wa
    Quote Originally Posted by urantia
    very good, this info should sort out my cousins aw11 with /beams, the tacho jumps around eratically, so it looks like the beams ecu is putting out a square wave form and the old tacho is expecting voltge spikes from the old 4age dizzy.
    Love learning stuff like this that i didnt know before! plus rep+
    In addition to this my tacho works better with more electrical load such as lights, heater, wipers and while using electric windows the tacho reads perfectly right up to 7400 rpm's.
    Long Time Reader Backyard Mechanic willwal98's Avatar
    I've got a gen3 1g-gte with a VDO tacho and it seems to read fine up until 4000rpm or so then won't go any higher. I have tried running it off both the signal wires on the coil (I believe there is something strange in there on a 1g, 2 ranges or something). One of them goes a little higher but then goes backwards. I have also made a signal booster which did SFA. Don't spose anyone could shed some light on this for me because I would really like a working tacho and don't really have the spare funds at the mo to pay someone to fix it.
    Hello.
    User Conversion King
    NWA
    there is a thin black wire coming from the engine thats in one of the plugs that dont connect to the ECU. get a multimeter and put it in resistance mode (beep mode) and put one probe in the "IG-" port in the diag box.....then just test everypin corresponding to a thin black wire on the loom (in the cabin).
    hello
  1. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 09:36 AM
  2. Tacho wiring [AE71 20v w/bosch coils]
    Last Post: 03-04-2006, 02:43 PM
  3. RPM Tacho Wire
    Last Post: 10-01-2006, 09:38 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
  5. Guidelines: Posting in Tech and Conversions
    Last Post: 20-09-2005, 04:42 PM
