Results 1 to 9 of 9
Thread: clutch.. what is the difference bewteen these two?
    May 2006
    tas
    Default clutch.. what is the difference bewteen these two?
    okay we are talking clutches here...
    ma70 7mge/w58
    jza80 2jzge /w58
    http://www.kudosmotorsports.com/cata...mge-p-649.html
    http://www.kudosmotorsports.com/cata...zge-p-623.html
    i dont know what the differences are? both are the same size diameter, both for w58 spline.
    bolt position/alignment studs different pressure plate to flywheel? obviously the actual flywheel isnt interchangeable (6 and 8bolt).
    i cant see the $190 differences between the two...
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Default Re: clutch.. what is the difference bewteen these two?
    hang on, you looking at a clutch for a A80 compared to a clutch for a A70. that's a W58 to a R154 mate. No go!
    Oct 2008
    TAS
    Quote Originally Posted by hks7mgt View Post
    only the turbo ma70s has the R154 box.
    ae71 is talking bout 2 cars running W58s
    1983 Toyota Celica Supra
    Quote Originally Posted by CELICASUPRA7M View Post
    ahh gotcha - sorry mate!
    May 2006
    tas
    yeah as above.
    just checked toyodiy, part numbers look a little different ma70 7mge>jza80 2jz (first series before the dash are the same). doesnt really confirm or not if they are interchangeable.
    -JZX83 in the build
    <3 7M sludge pump
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    i plan on using a 7m one on my 2jzge for the same price reason, shall see how it goes
    1ggte ones should be similar too
    May 2006
    tas
    making so many things interchangeable having a different clutch cover seems illogical.
    -JZX83 in the build
    <3 7M sludge pump
    I looked up the exedy website a while ago and from memory they had the part numbers of the components, and the plates were the same / pp different. Or maybe that was by calling them.. i forget. I assumed this was just bolt pattern, which doesn't really explain any price difference, aside from jza80 tax..
    They should be the same.
    I've personally used a 7mge W58 clutch & PP on a 2JZ-GE (W58) Flywheel.
    Wilbo's JZA80
    Wilbo's JZZ12
  1. Clutch for R154
    By millers in forum Tech and Conversions
    Last Post: 21-11-2008, 03:30 PM
  2. Twin plate clutch - dramas
    By spiller in forum Tech and Conversions
    Last Post: 09-11-2007, 02:46 AM
  3. Clutch dramas
    By wagonist in forum Tech and Conversions
    Last Post: 17-10-2007, 02:23 PM
  4. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 10:12 AM
