Results 1 to 4 of 4
Thread: 4agze really high idle, video..plus more help :(
    Apr 2009
    Default 4agze really high idle, video..plus more help :(
    After solving my spark problem the engine now starts. Problem now is that it has a ridiculously high idle and it varies from about 3500 to 4500. All the vacuum lines have been checked with the only ones not connected are the ones after the throttle body.
    As well as this there is this squealing noise which sounds like It's coming from the inlet area.
    I've added a video but disregard the hand over the inlet as it would stall even if I didn't place my hand over it.
    Where shall I start? Help!
    http://img.photobucket.com/albums/07...MDA3LjNncA.mp4
    Apr 2009
    Default Re: 4agze really high idle, video..plus more help :(
    Oh and the throttle body is shut.
    Also it would stall after running between 30 secs and a 5 secs (which of course is the video above...)
    Chiba
    If there is any open ports or fittings between the throttle body and head, the car will rev high.
    Did you reuse any gaskets, and clean all mating surfaces when you replaced any gaskets after you opened any joins in the pipework up?
    Throttle body to J-pipe
    Both sides of the supercharger
    Intercooler to intake manifold
    Intake manifold to head
    Also make sure all your pipes are free of cracks etc.
    That noise sounds like a whistle from a leak in the intake somewhere. Find the whistle and I reckon you'll find the cause of the high idle.
    ^^ there's your answer. fix that first and try again.
  1. 2JZ-GE High Idle
    By ark_112 in forum Tech and Conversions
    Last Post: 09-04-2009, 12:13 AM
  2. 4AGZE high idle but no boost leaks
    By .:2DR-FTU:. in forum Tech and Conversions
    Last Post: 20-05-2008, 03:48 PM
  3. Erratic Idle on MAP 4AGZE
    By PooJou in forum Tech and Conversions
    Last Post: 24-03-2006, 02:33 PM
  4. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 04:08 AM
